20 Most Recent NEC 42VP4 42 in. EDTV-Ready Plasma Television Questions & Answers
2answers
Model number is px-42vm2a needhelp to hook it up
Here is a link to the manual to your nec unit. It should include all the information how to hook up any device to it. Hope this helps. :]
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=8d9fd87379fdae72cdf2daa2c14945c0&q=NEC+PX-42VM2A
7/31/2012 7:59:23 PM • NEC 42VP4 42 in.... • Answered on Jul 31, 2012
0answers
How do I connect a
This depends on how you have it hooked up. You're going to need a Tuner. A simple method is to connect only the Yellow RCA cable (or composite cables) to your T.V. Then connect Red and White RCA cables to the Tuner/Surround sound system you're using on which ever input you're comfortable with. I.E. CD/AUX/TAPE..etc. Change your tuner to that input, and you should get your surround sound through the speakers. Make sure you change the input on your T.V. to what ever video source you got the wires in. If your tuner allows you to hook up a video source to it, you can just hook it up to the tuner and run the DVD player off the tuner only. The first option helps avoid confusion if your tuner isn't set up for any other devices to play video through it.
6/24/2011 11:40:15 PM • NEC 42VP4 42 in.... • Answered on Jun 24, 2011
NEC plasma tv.........how the heck do i hook it up?
Hi i have a NEC PlasmaSync Plasma Monitor which was given to me ages age, im trying to connect an antenna to watch free to air tv but there dosnt seem to be one?? The model is Px42vm5hw.. can anybody help me as i have watched every dvd i own!!!
11/17/2009 1:54:49 AM • NEC 42VP4 42 in.... • Answered on Nov 17, 2009
3answers
NEC PX-42VP4DA
te power pack inside the tv has gone bad and needs replacement, contact manufacturer for parts.
4/7/2009 3:12:50 AM • NEC 42VP4 42 in.... • Answered on Apr 07, 2009
TV shutting off by itself
The plasma panels operate on 170VDC and 60VDC, Sound like the 170VDC from the power supply is low or dropping low. You need a tech to look at it, the voltage sources are marked on the board and the adjustment is labeled. Typically a component such as a regulator or capacitor is leaking to cause the voltage to drop.
Al
2/28/2008 12:32:25 AM • NEC 42VP4 42 in.... • Answered on Feb 28, 2008
2answers
What might be the problem
Sounds like you had a power supply go bad in the unit which would require some extensive troubleshooting. I'd recommend a repair facility since it may be time consuming without mfg support.
2/4/2008 9:44:28 PM • NEC 42VP4 42 in.... • Answered on Feb 04, 2008
Power Supply
I have the same problem,
first poser supply lasted just over three years at 92-- foot elevation,  the next one lasted 3 months, just long enough to get past parts warranty, and NEC/local tech wants $800 to replace the power supply that took 3 months to get in before.
Nope, just bought a new HD Vizio and moved on.  Better picture and BIGGER picture.
10/21/2007 4:53:20 PM • NEC 42VP4 42 in.... • Answered on Oct 21, 2007
Sound:
Check in the menu to see if the speakers are turned off. If not report back here.
9/11/2007 8:38:35 PM • NEC 42VP4 42 in.... • Answered on Sep 11, 2007
Where can i get a tv stand.
You can purchase a tv stand from Amazon or your local Walmart I believe they have them in stock.
8/7/2022 3:51:21 AM • NEC Televison &... • Answered on Aug 07, 2022
What do these brakes on tape spool wheels do in my NEC N917U VCR?
andrew answered this yesterday and someone deleted it. its to keep the tape from freespooling
5/1/2021 3:46:23 PM • NEC Televison &... • Answered on May 01, 2021
I don't have a remote how can change settings with just the tv buttons it is an nec nlt-32xt2 model.
Try going to the NEC website and download a user manual >>> http://www.generalmanual.com/Televisions/NEC-NLT-32XT1-LCD-Television.htm <<< That would I think, have the instructions about doing just that. Regards Geoff
1/7/2020 7:06:39 AM • NEC Televison &... • Answered on Jan 07, 2020
Do I need a converter box for my 32 in NEC flatscreen
Depends on the model!
8/25/2019 6:38:16 AM • NEC Televison &... • Answered on Aug 25, 2019
Trying to connect Bauhn tv to NEC model VN-25. Back of video player has audio L &R out and video out with 2 plug points
is it r,w,y on top of each other? choose one and see if functions 1 may say in oter out
5/12/2019 8:18:00 AM • NEC Televison &... • Answered on May 12, 2019
Trying to connect Bauhn 54 4K UHD LED LCD TV to a NEC model VN-25 VCR.
Does the VCR have Component outputs( Red/White?Yellow)? If yes use AV1 to connect them
5/12/2019 8:12:52 AM • NEC Televison &... • Answered on May 12, 2019
3answers
How do I remove teletext?
The teletext button on the remote control handset, has usually a toggle action. One press for on and another press for off.
Hope that helps.
4/9/2019 9:03:20 AM • NEC Televison &... • Answered on Apr 09, 2019
NEC 42VP4 42 in. EDTV-Ready Plasma Television Logo
Popular Tags
15 questions posted
Top NEC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • NEC Televison & Video
Most Popular Question
nec plasma tv heck hook up
  • Televison & Video
