monitor problemTo whom it may concern, i have a problem with may PROVIEW CRT Monitor, when i turn it on the monitor generate sounds...
1 Solution
Dell 172FPb problemI have read several...no, many threads but I have not found an answer. Maybe missed it. The power indicator is on...
1 Solution
CTXI get this error message when I connect this monitor to any pc "no RGB signal". What is causing this....
1 Solution
View All
Specifications
Key Features
Aspect Ratio5:4 (Regular) Max. Resolution1600 x 1200 Viewable Picture Size20 in.
Technical Features
Regulatory ApprovalUL · cUL · FCC Class B · C-Tick · CSA · ISO 9241-3 · VCCI · CRA · TUV-GS · DHHS · DOC-B · Energy star · SEMKO · MPR-II · GOST-R · ISO 9241-7 · ISO 9241-8 Synchronization Range - Horizontal30 - 96 kHz Native (Recommended) Resolution1280 x 1024 Resolutions supported1280 x 1024 · 1600 x 1200 · 800 x 600 · 640 x 480 · 1024 x 768 · 832 x 624 · 1152 x 870 · 720 x 400 Synchronization Range - Vertical55 - 160 Hz
Dimensions
Warranty
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
