NEC AccuSync LCD52V  15" LCD Monitor
Problems with NEC AccuSync LCD52V 15" LCD Monitor?
Keep your PC up-to-date. Get a Free Scan for NEC's latest driver updates.
Troubleshooting and Support
Solved Problems for NEC AccuSync LCD52V  15" LCD Monitor RSS Feed Post a New Problem
Monitor resolution can't be changed
My Monitor is DAEWOO 15". I am working on 800x600 resolution. I want to change to 1024x768 but it can't be changed....
1 Solution
LG 500G MONITOR
IN MY MONITOR HORIZONTAL OUTPUT TRANSISTOR(C5855) FOUND SHORT. I REPLACED IT BUT AFTER FEW MINUITS IT BECAME...
1 Solution
hi lcd
hi, the screen of my monitor(computer) when i open a some game are shaking
1 Solution
monitor takes 1/2 hour to warm up
when switching on my computer it takes at least 1/2 hr for the monitor to show anything, once the images appear...
1 Solution
hi light is going dim day by day
i am using microtek monitor..but the light/brightness is going dim day by day...what is the problem what should i do?...
1 Solution
Connecting my LCDTV upto my Computer
I'm trying to connect my LCD Monitor to my computer and when i follow the instructions in my manual it tells me to go...
1 Solution
speakers
I only get sound out of the right speaker (when looking at the monitor.) When I plug in headphones I still only get...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Aspect Ratio4:3
Size15"
Color Depth24-bit (16.7M colors)
Contrast Ratio400:1
Brightness250 cd/m??
Max. Resolution1024 x 768
Dot Pitch.297 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Viewable Picture Size15 in.
Technical Features
Form FactorDesktop
Regulatory ApprovalISO 13406-2 (Pixel defect guidelines)
Synchronization Range - Horizontal31.5 - 60 kHz
Max. Viewing Angle - Horizontal140
Max. Viewing Angle - Vertical100
Native (Recommended) Resolution1024 x 768
Resolutions supported800 x 600 · 640 x 480 · 1024 x 768 · 720 x 400 · 832 x624
Synchronization Range - Vertical56 - 75 Hz
Dimensions
Depth2.3 in.
Height11.2 in.
Width13.6 In.
Weight6.2 lb.
Warranty
Warranty3 Years
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
Loading problems.
Top Experts
Ask Me
jerryg50 Wiz
2 solutions
Ask Me
Dsolo Wiz
3 solutions
Ask Me
Thexder1 Wiz
1 solutions
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
