FixYa.com
NEC Fan Assembly
All Products > NEC > System Cooling
Problems with NEC Fan Assembly?
Search inside NEC Fan Assembly Knowledgebase
Troubleshooting and Support
Solved Problems for NEC Fan Assembly RSS Feed Post a New Problem
How to replace a fluorescent starter
How do I replace a fluorescent starter?
1 Solution
The tip of plug for AC Adapter is very hot...
I noticed that the tip of the plug for AC Adapter is very hot to touch while charging the battery.  Is that normal...
2 Solutions
jeep cooling problem
i have fixed the thermostat, replaced the head gasket, and had the radiator redone. the temp gets to about 240-260 and...
1 Solution
TOYOTA CAMRY 1990 COOLING SYSTEM
overheating fan wont engage
1 Solution
Acer 4672 Freezing
Hello,I am having some issues with an Acer 4672 freezing. I have reinstalled the operating system and it still freezes....
2 Solutions
converting airshocks into regular shocks
I have a 1989 Lincoln Mach 7 with air shocks. They have gone out and wewant to convert it into regular shocks. What do I...
1 Solution
HP dv1000 cooling fan does not turn on
Dear Sir/Madam, I have a problem with HP dv1000 cooling fan. The Fan never turns on even if the laptop is hotter. How to...
2 Solutions
View All
Tips & Tricks
Post a New Tip
Specifications
Properties
Product ID28600890
TypeFan Assembly
MPN136020414802A
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
