NEC LT20 Multimedia Projector
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with NEC LT20 Multimedia Projector?
Troubleshooting and Support
Solved Problems for NEC LT20 Multimedia Projector RSS Feed Post a New Problem
security code for Nec lt260 multimedia...
i believe the instruction you give me last time is to delete menu or logo password.That not exactly what im looking...
1 Solution
security code
could you tell me how to break or reset security code on nec lt 260multimedia projector.Plus i didnt have a remote...
1 Solution
Projected screen
When I turn on the projector, the projected computer screen is only about half the size. What is the problem? What must...
1 Solution
Sanyo Projector==No signal
Sanyo projector is not registering a signal when connected to a Dell laptop. I followed set-up procedure--first,...
1 Solution
sharp digital multi media projector PG...
Screen show keeps cutting out for 5 - 20 secs although the projector is still operating and somes back on...
1 Solution
vt45 projector turns off without notice.
The projector turns off while in use. It doesn't really needto be "too hot". It may be in the first few...
1 Solution
In Focus X2 projector won't display...
In Focus X2 projector won't display welcome screen. It turns on, the fan goes on too and the green light is steady. I...
1 Solution
Unsolved Support Problems
Unsolved Problems for NEC LT20 Multimedia Projector RSS Feed Post a New Problem
Nec LT 20 Projector
When power turns on orange power light comes on with fan for 10 secs. Then, light turns green and flashes. Fan not...
Post a Solution
NEC LT20 projector
Three lines on the left hand of display - not matter what it's hooked up to. Any ideas?
Post a Solution
image is upside down on projector
Hi I have a NEC VT 490 and all I need to know is how do I adjust the image so that it is not upside down, as I have had...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
PlatformPC · Mac
TypeDLP Projector
Form FactorPortable
Display TechnologyDLP
Image Brightness1500 ANSI lumens
Contrast Ratio2100:1
Image Aspect Ratio4:3 (Standard)
Analog Video FormatNTSC · PAL · PAL-M · PAL-N · SECAM · NTSC 4.43
Image Size (Diagonal)31.5 in. - 246.06 in.
Screen Distance4.92 ft. - 32.81 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1400 x 1050 (SXGA+)
Synchronization Range Horizontal15 - 85 kHz
Synchronization Range Vertical50 - 85 Hz
HDTV Formats720p · 1080i · 480p · 576p · 625p
Technical Features
Operation Noise34 dB
Interfaces
Video Input4 Pin - Mini DIN (S-Video) · 15 Pin D-Sub VGA (& component) · Composite Video
Lamp
Lamp TypeP-VIP
Light Source Life3000 Hours
Light Source Power156W P-VIP
Other Features
Special FeaturesOn Screen Menu · Keystone Correction
Projection MethodRear · Front · Ceiling
Warranty
Warranty3 Years, 120 Days On Lamp
Dimensions
Depth5.93 in.
Height2.21 in.
Width7.87 in.
Weight2.21 lb.
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
Loading problems.
Top Multimedia Projector Experts
ginko
3 solutions
Modems, TV and Video, Cameras and Photography...
Ask Me
Guru
SparkGap
1 solutions
Modems, Satellite Radio Receivers, Shavers...
Ask Me
Wiz
Marrie
15 solutions
Multimedia Projector Replacement Lamps...
Ask Me
Guru
Repair Service
Find Multimedia Pro. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
