20 Most Recent NetGear WPN111 RangeMax Wireless USB 2.0 Adapter: WPN111NA (NTUSNGWPN111) Questions & Answers
WEP key you set up on your own in router configuration/setup.
Cheers,
Mike
Leave rate if I helped you, thanks!
NetGear WPN111... | Answered on Jun 29, 2013
Try disabling the Windows Driver, so that it doesn't stomp on it.
NetGear WPN111... | Answered on Dec 18, 2011
Download the latest drivers, wpn111 3.0 from netgear website, install, restart, if problem persist;
open control panel, add hardware, manually install the device drivers, usually the list it shows you has a yellow mark. After doing this you should be able to open and follow the instructions.
I had the same problem and this it solved it.
Hello subaikri,
I've given you a "Link to the Website, where you can,
"Download the Drivers / Software, that you need."
First, make sure that the you choose the other than; if not -> Windows 7?
**{New Drivers / Software"}!
"All other apply to "Vista!" e.g: WPN111 Software Release Version 2.1...
Scroll-down the (page), until you see the "Software."
There will be a {List}, to choose from!
This way, you'll be able to get the right "Drivers / Software."
Next, download the [File].
Find the {File, and "Install the Driver / Software"}.
"Restart the computer, so that the configuration can make the 'correct' changes.
If you need help with anything else?
"Write a 'comment'; I'll be here to assist you!"
"Best Regards"
Click here for "Drivers"
http://support.netgear.com/app/products/model/a_id/2620
NetGear WPN111... | Answered on Aug 17, 2011
For that over heat netgear wifi try connect other USB ports of your desktop or laptop.observe again.maybe over volts come out.
NetGear WPN111... | Answered on May 28, 2011
Sometimes you will get a false low signal strength indication, but here's something to try anyways.
Imagine if we lived in a society where all TV signals came in on the same channels.
If you are watching channel 11, but 3 other tv stations are broadcasting along with the one you want to watch, it takes a lot more effort to get the information you want from the one station you are trying to watch.
So lets say you and your tv station strike up a deal, and they move to channel 6...and nobody else in the area is on channel 6...great, now you can watch your program effortlessly.
Wireless can be like that, and most routers are factory configured to channel 11.
Look in your router manual or pdf guide or whatever instructions you have for it, and change the wireless channel.
I have found in the past that you can go from poor signal with frequent disconnects, to full signal strength at the highest speed and no disconnects, just by choosing a better channel (and yes, I usually pick 6 first, and only try others if necessary).
NetGear WPN111... | Answered on Feb 27, 2011
This can occur when the wireless adapter has trouble connecting to the wireless router.
It may not get an IP address from the router or the wireless adapter encryption setting didn't get an the encryption authentication from the router.
In this case right click on the wireless adapter on the Task bar and click Repair. This will make the router re-issue an IP address and authenticate the adapter's encryption setting.
NetGear WPN111... | Answered on Feb 19, 2011
As i know yes you can.Just do the setup and post back any problems.
NetGear WPN111... | Answered on Jan 04, 2011
No definitely not....
If you want your Xbox to be wireless, then you need to buy Xbox wireless adapter...
Bcoz the Xbox wireless adapter comes with a pre-built in drivers....
but other brand wireless adapter donot comes with a built in drivers, you need to install the drivers using a driver cd....But Xbox do not allow driver cd's to be installed on it... so you will not be able to use ordinary wireless adapter instead of Xbox wifi adapter...
NetGear WPN111... | Answered on Dec 10, 2010
Are you sure the problem is between your USB adapter and your router? I've had similar issues with my connection but the problem was with the router itself. I've downloaded a new version of the router firmware and everything has been fine since the upgrade.
NetGear WPN111... | Answered on Sep 27, 2010
Ventilation is the problem of your netgear wireless adapter losing signal when it gets hot, you will need to get a good place that the ventilation is cool and cold enough to help cool the adapter.
I work in an ISP company, anytime the our air conditionig in the server room breaks down, we experience bad internet services because the internet will either be very slow or not going at all, ll we use to do is to makesure the server i protected by getting a a standing fan standby near the server incse of the ac failure.
So, your case is very glaring to me that, the ventilation is the problem, you will need to get a cool or cold environment to work with your adapter, with this, it will never get hot and lose signal.
Take care.
NetGear WPN111... | Answered on Jun 13, 2010
do you have the install disc for te netgear router ?
you have to have one
NetGear WPN111... | Answered on Jun 07, 2010
Hi
firstly you can try upgrading the drivers on the adapter. following is the link for the latest drivers http://kb.netgear.com/app/answers/detail/a_id/12520
If the problem still persists
try changing the wireless settings on the wireless router.
NetGear WPN111... | Answered on Apr 07, 2010
Do the protocols match?
Did you install the drivers for the wireless card?
If they do and you did then the wireless card is no good.
NetGear WPN111... | Answered on Mar 27, 2010
please downlaod latest driver for adapter then install in computer
link for latest driver
regards
prakash
NetGear WPN111... | Answered on Mar 21, 2010
it seems that driver is not install properly
1.reinstall CD or download latest driver from netgear website and install in computer
regards
prakash
NetGear WPN111... | Answered on Mar 19, 2010
please download latest driver for adapter and install in computer
please download latest driver for this adapter and install in computer
http://kb.netgear.com/app/products/model/a_id/2620
Computers & Internet Logo
50 questions posted
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
RangeMax NetGear
  • RangeMax NetGear
Most Popular Question
netgear wpn111 smart wizard auto shut
  • Computers & Internet
