20 Most Recent Nokia 9300 Smartphone Questions & Answers
my nokia 9300 is on offline mode, I'm pressing the switch buttom, it's showing only offline profile is active.?Kindly suggest me what to do???
Nokia 9300... | Answered on Oct 12, 2016
puk 8991930108061447668
Nokia 9300... | Answered on Jun 09, 2013
hey buddy try to download applications which are muchly compatible to your phones symbian version, 9300 is S80 v2.. drop me an email so i can give you the list of mobile sites where you can download lots of mobile applications and software related to your phone.
Nokia 9300... | Answered on Jan 15, 2013
try to format it via thish code
remove sim and memory
and also battery
press ctrl+shift+f+on off swith and insert battery phone ask u format
if ur fault solve dont forgate thanx
Nokia 9300... | Answered on May 30, 2012
how code format nokia 9300 comunicator
Nokia 9300... | Answered on May 21, 2012
Hi i stay in Eldo's look for motherboard for nokia9300i
Nokia 9300... | Answered on Sep 06, 2011
Welcome to FixYa!
Your phone is clearly having an LCD problem. The best thing that you can do is to full charge the battery and see if anything changes with the battery fully charged.
If it is still in negative colour even if the battery is fully charged, then you need to tighten the LCD screw and see if anything changes. If not, then the LCD needs to be replaced. You need to service your phone to a repair shop because it needs a special star screw driver to tighten or replace the LCD.
Thank you for using FixYa. Have a great day. jas247
Nokia 9300... | Answered on May 19, 2011
I am from pudukkottai near trichirapall(trichy) TAMILNADU state.I need NOKIA 9300 STRIP TO repair my phone. so kindly tell me how cost it is and how can i get it.
MY E-MAIL ID is sureshkumar.auk@gmail.com
thank you
Nokia 9300... | Answered on Feb 11, 2011
First of all, is the main screen on your phone working? If it is, you can change the offline mode from there, all you have to do is to press the power on/off button from there and scroll down from the direction button, then you press the middle button of the navigation button, that selects option for you.
But if you cannot see anything on the outer and inner screen, then it means you will have to navigate blindly, it is simple, turn off the phone by pressing and holding the power off/on button and turn it back on, then you press the power off/on button once, scroll down once, and select the option, that way your phone will be out of offline mode.
The problem with your phone that is not allowing the screen to work is that the flex of the phone is weak and not being able to connect the phones information to the screen. Once it is fixed, that should do the job for you.
Hope this information helped you.
Nokia 9300... | Answered on Jan 12, 2011
first u switch off ur mobile then press 3,*, dial butten at a time on ur mobile it was farmat ur mobile then ur code change to default 12345 ok.
Nokia 9300... | Answered on Dec 24, 2010
Inorder to format your set,you can use following tips; FOR HIGHER ORDER PHONES(LIKE N,X,E series..): Dial *#7370# then your phone will ask a securitycode,there you can type your code.then it wil format and restart.
FOR OTHER MULTIMEDIA NOKIA PHONES: Here you can't format yourphone,but you can reset it; For that,go to;SETTINGS-RESTORE FACTORY SETTINGS- AFTER CLICKING IT, your phone will ask a securitycode there you can type your code.then it wil format and restart. "IF YOU THINK MY SOLUTION IS HELP FULL TO YOU,THEN DON'T FORGET TO RATE ME"....THANK'S
Nokia 9300... | Answered on Nov 13, 2010
That can be a software bug. Try a general reset of the phone and see if this problem is back. If it is, do a Operating System update with a cable and Nokia Suite software. Your PC must be connected to internet.
Nokia 9300... | Answered on Nov 02, 2010
Here is the link to the user manual for your Nokia 9300. It will tell you how to control the volume.
http://nds1.nokia.com/phones/files/guides/Nokia_9300_UG_en.pdf
Nokia 9300... | Answered on Oct 19, 2010
Nokia 9300 Smartphone Logo
107 questions posted
Popular Products
Top Nokia Computers & Internet Experts
Anthony Ward
Anthony Ward
k24674
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Nokia Computers & Internet
Most Popular Question
nokia 9300 offline mode pressing
  • Computers & Internet
