360 people viewed this product
One of the components in the defrost circuit is not working - preventing it from melting frost & ice...
The valve may still work electrically but not opening mechanically. The part is=> 67006322 Water Inl...
Wipe down the contact area on the door and corresponding area of the inside of the fridge. if this doe...
try filling the icemaker tray mold manually with about 4 ounces of tap water from the front of the ice...
If it runs but doesn't cool that's bad news, time to go frig.shopping.
What is the model number of the unit?
What is the model number and is the compressor kicking on?
If your refrigerator is not cooling, the problem could be as simple as a covered vent or som...
I'm not an a/c expert but, as a homeowner I experienced the same thing with my old house A/C uni...
sounds like you have a bad damper,if you go here and look at part number 13 you can see it htt...
You have a bad bi-metal switch. Turn off the refrigerator unscrew the back panel of the freezer use a h...
it sounds like you have a bad jazz board part 12868513,go here to see it htt...
HI.I WOULD TRY DEFROSTING ALL FIRST TO RULE OUT ICE BUILD UP JAMMING THE WINDOW FLAPPS.MAKE SURE IS ALL...
Have a tip for Maytag PTB1551GR Top Freezer Refrigerator?
I have a Maytag PTB1954 . Freezer above fridge. Purchased in 2002 and still under warranty . Has 10...
| Key Features | |||
| Full Product Name | Maytag PTB1551GR Top Freezer Refrigerator | ||
| Type | Top Freezer | ||
| Total Volume | 15 cu. ft. / 425 liter | ||
| Ice Maker | Optional Ice Maker | ||
| Total Number of Shelves | 2 | ||
| Fresh Food Compartment | |||
| Door Opens | Opens to Left and Right | ||
| Dimensions | |||
| Overall Depth | 31.13 in. | ||
| Overall Height | 61.25 in. | ||
| Overall Width | 27.5 in. | ||
| Warranty | |||
| Warranty | 1 Year Parts and Labor | ||
| Warranty | 5 Years Parts (Sealed System) | ||
