FixYa.com
Parallel 2 Ports Serial ATA150 Raid Controller Card
All Products > Parallel > Storage Controllers
Problems with Parallel 2 Ports Serial ATA150 Raid Controller Card?
Search inside Parallel 2 Ports Serial ATA150 Raid... Knowledgebase
Troubleshooting and Support
Solved Problems for Parallel 2 Ports Serial ATA150 Raid Controller Card RSS Feed Post a New Problem
Mp3 that does not work
My mr3 player "etec" is not working. It does not work and if I put it in my computer it makes an error message...
7 Solutions
Packard Bell Store and Save H2D2U2...
The unit status LED stays red for 5-6 minutes after turning on and seems to strugle to save data. I have tried defraging...
2 Solutions
Installation of new hard drive
Hello I have recently installed a new PATA hard drive in my PC- the CPU is an Athlon 2600+ and the motherboard is an...
2 Solutions
250GB Samsung 7200 rpm SATA300 hard disk,...
I am about to order a system with two of these drives installed. I want to run up Red Hat Enterprise Linux AS 3.0...
1 Solution
sony 1gb flash drive
no files inside my flashdrive but when i check on properties,it show a lot of space has been used
1 Solution
My new HDD isnt showing up in my computor
I bought a new HDD today, I have installed it correctly. The BIOS can't find it in the standard CMOS setup but in the...
1 Solution
cant use sd card
i want to save to sd card on a sandisk mp3 player. The computer tells me it only has the memory it comes with but i want...
1 Solution
View All
Tips & Tricks
Post a New Tip
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
