20 Most Recent
RCA HD61LPW165 61" Projection HDTV Questions & Answers
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
50" RCA DLP color wheel replacement procedure
Mine started to howl last year, I sprayed out the motor using carb cleaner / lubricant. Its been running fine for over a year since.
My guess is, the bushing gets plugged with dust particals. If you catch it as soon as it starts to squeek, the carb cleaner trick may work for you too.
Lost picture but sound is on
almost certain this is a lamp problem, bulbs blow up
if you remove the lamp you can see if the bulb is broken inside.
How do I remove the color wheel for an RCA
if you are talking about the light engine, your best bet is to have a tech do it. if you are really talking about the color wheel, in my experience they are replaced not repaired ..
I have a 2005 rca
that would be the color wheel as if it was the fan it would have stopped by now. So yes
check the color wheel by all means, let me know what you find, please do click the accept button for my efforts, thanks Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
62" RCA dlp loses color
If you hear any winding, whirling or screeching noise (Color Wheel symptoms)
If there is any vibrations in the TV (Color Wheel symptoms) you would need to change the color wheel.
Have multiple white spots projected
You have a faulty DMD module. It has millions of microscopic mirrors that are responsible for reflecting light onto the color wheel and produce an image. A common problem on projection tvs and the only solution is to replace the DMD module. The part costs around 300$ and is a DIY repair if you have prior experience in electronics as you have to slide out the chassis to replace it hence you should know what not to touch. A service manual should be off mighty help for this repair so I will check if I have one for this model.
