20 Most Recent RCA 24F501TDV 24" TV Questions & Answers
its not a hd ready - hd tv on crt are very rare and i think samsung did 2 models, hd ready - is not the same as full hd
RCA 24F501TDV... | Answered on Jul 23, 2014
Hi:
Have the flyback transformer replaced, also on RCA models it is common pratice to replace the Horizontal Output Transistor replaced also, as these parts work in conjunction with each other, when one fails the best repair solution is to replace them both because or major stress due to one or the other failing..
RCA 24F501TDV... | Answered on Jan 21, 2010
Hi
Check the system of your tv! maybe the settings of system is wrong! check the system PAL SECAM NTSC. put the settings in to auto mode.
Thanks!
RCA 24F501TDV... | Answered on Dec 28, 2008
you may need to change your resolution on tv settings as well as cable or satelite settings if you have one of those
RCA 24F501TDV... | Answered on Dec 12, 2008
Replace the DVD unit part#265278. It shows as NLA but do some searching.
RCA 24F501TDV... | Answered on Feb 01, 2007
could be the power supply , check the ballast if the part is ok most likely is the power unit
RCA Televison &... | Answered 1 hour ago
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
https://electronicshelponline.blogspot.com/
https://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview]
RCA Televison &... | Answered 15 hours ago
At first, you should make sure that the remote control you have, had a code for your TV brand. If yes, you can program that remote control to control your TV. Make sure it first. If there is no code said, you can't.
Programming Notes
Google (rca)(RC32E6L)(manual) without parens OR contact RCA directly to request it.
RCA Televison &... | Answered Yesterday
You can find the Owner's Manual and the Programming guide at the Voxx International Zendesk site for the antenna rotator: https://voxxintl.zendesk.com/hc/en-us/articles/225488908-Information-Owners-Manual-and-Support-for-the-RCA-VH126N-Antenna-Rotator . The Owner's Manual has the installation directions; the current link to the manual is http://www.voxxintl.com/search/?sku=VH126N&t=OM .
I hope this helps.
RCA Televison &... | Answered on Sep 13, 2019
Does anyone have a answer for this problem I'm going through the same thing here?
RCA Televison &... | Answered on Sep 12, 2019
Hi Yvonne, as you comment, there may be two reasons for failure, the internal RCA straps stretched and therefore fail to transmit the movement so that it works correctly and the other reason, the VHS tapes, which are wet
Observe through the two upper windows of the Video cassette, that the tape is without any white spots, if white spots appear, these are due to moisture and the tape with humidity, it cannot move correctly inside the video cassette, and can cause the fault what do you describe
Also verify that the drum of the video heads is clean and free of moisture
I hope you can watch your videos
Regards Franco Dosil
Hola Yvonne, por lo que comentas, puede haber dos motivos de falla, las correas internas del RCA estiradas y por lo tanto no logran trasmitir el movimiento para que fun cione correctamente y el otro motivo, las cintas VHS, que se encuentren humedas
Observa por las dos ventanas superiores del Video cassette, que la cinta se encuentre sin ninguna mancha blanca, si te aparecen manchas blancas, estas son por humedad y la cinta con humedad, no puede desplazarse correctamente dentro de la video cassettera, pudiendo producir la falla que describes
Verifica tambien que el tambor de los cabezales de video, se encuentre limpio y sin humedad
Espero puedas ver tus videos
Saludos Franco Dosil
RCA Televison &... | Answered on Sep 04, 2019
Hi Ernest, you can have a problem both on the Power Supply board, as well as on the Main Board
Hola Ernest, puedes tener problema tanto en la placa de Fuente de Alimentacion, como asi tambien en la Placa Principal
RCA Televison &... | Answered on Sep 03, 2019
RCA 24F501TDV 24" TV Logo
12 questions posted
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
picture rolls
  • Televison & Video
