FixYa.com
Ricoh Aficio 2020D Grayscale Copier
All Products > Ricoh > Copiers
Problems with Ricoh Aficio 2020D Grayscale Copier?
Troubleshooting and Support
Solved Problems for Ricoh Aficio 2020D Grayscale Copier RSS Feed Post a New Problem
right door off hinge, cannot get back on
Was recieving a fax when the error came up to check right door and follow directions. When I went to open the door, it...
1 Solution
Failed message
I am receiving a --- update destination list failed. Please tell me how to solve this-- Thank you, Denise Brown-Sutton
2 Solutions
printing & copying blank pages
Useing a Xerox Workcentre M20i weather printing or coyping the pages are blank. Have changed out the toner still blank.
1 Solution
Riso GR3770 Paper Jam, Check paper feed
I got an adhesive label stuck up in the center of my paper feed.  Long story, short, I have to disassemble the...
1 Solution
Canon copy machine NP6025. Error E800.
When I turn on my copier I get this Error E800 which tells me to turn the copier off, and then back on again. I've found...
1 Solution
canon c3200 copier
need to replace transfer unit can you help
1 Solution
SOFTWARE FOR CANON
WE NEED TO GET THE SOFTWARE FOR A CANON F189402 PRINTER.
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Ricoh Aficio 2020D Grayscale Copier RSS Feed Post a New Problem
capacitors
none of them is bulged. The most of them got voltage on that decreases when mesured (should be ok) one has no...
Post a Solution
testing capacitors
do i have to take them all of the print to test them or can i do it otherwise? And what value shows me a capacitor is...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Copier ColorGrayscale
Max. Black Cpm21
Copy Ratio50% - 200%
Best Resolution600 dpi
Multifunction CapabilityScanner, Printer, Fax
ENERGY STARWith Energy Star
Copier Specification
Max Media SizeUp to 11 x 17 in.
Max Sheet Capacity500
Auto Document FeederWithout Auto Doc. Feeder
Media TypesPlain Paper, Envelopes, Books
First Copy Time6.5 sec
Facsimile Specifications
Fax Speed33600 bps
Fax Transmission Speed3 sec/page
Dimensions
Depth22.36 in.
Height16.54 in.
Width21.65 in.
Weight78 lb.
Ricoh Contact Information
Main support number800-327-8349 / 800-637-4264
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
