FixYa.com
Ricoh IS450 Flatbed Scanner
All Products > Ricoh > Scanners
Problems with Ricoh IS450 Flatbed Scanner?
Search inside Ricoh IS450 Flatbed Scanner Knowledgebase
Troubleshooting and Support
Solved Problems for Ricoh IS450 Flatbed Scanner RSS Feed Post a New Problem
How to test a scanner for color...
How to test a scanner for color registration?
1 Solution
I unhooked by scanner ro rearrange some...
I unhooked by scanner ro rearrange some equipment and forgot how it was connected. I think it should be as follows:...
1 Solution
How to Clean a Scanner?
1 Solution
"A HI SPEED USB device plugged into a...
"A HI SPEED USB device plugged into a non HI SPEED USB hub" error message, any idea?
1 Solution
not support window xp
acer scan 620st bit suport window xp
1 Solution
Microtek artix scan 120tf
My microtek negative scans are coming out with a very strong cyan bias, and i consistently get a light cyan strip all...
1 Solution
How to add more pages while scanning with...
Is is to possible to insert / add-on more pages, while doing scanning with Umax Astra 5600 Thanks & regards
2 Solutions
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeFlatbed Scanner
InterfaceSCSI-2 (8-bit)
Optical Resolution400 dpi
Max. Resolution (Hardware)400 x 400 dpi
Technical Features
Form FactorDesktop
Input TypeMonochrome
Automatic Document Feeder Capacity150 Pages
Media
Supported Media TypePlain Paper
Media Loading MethodAutomatic Document Feeder
Max. Supported Media SizeA3 (279.4 x 431.8 mm)
Dimensions
Depth27 in.
Width18.5 in.
Weight57 lb.
Ricoh Contact Information
Main support number800-327-8349 / 800-637-4264
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
