20 Most Recent
Linksys Wrt54g-tm Wifi Wireless Router, Repeater, Vpn W/ Dd-wrt Mega & Heatsink Questions & Answers
Frontier router
Frontier Router Login at the bottom of the Network Connections window, just below the address bar. Select Wireless Properties from the menu. Locate the Network security key field on the Security tab. You'll see your Wi-Fi network password if you click the box for Show characters.
1/28/2022 7:46:04 AM •
Linksys...
Answered
on Jan 28, 2022
How to Fix Linksys Router Error 2118?
This seems to be a symptom of a configuration error, which can be fixed by resetting the router to factory default. Do this by finding the (often partially hidden) reset button on the device, and pressing and holding down the button, with the power on, till lights start flashing on the router. Let go of the button and allow the router to reset (can take a minute or two). You will now have reset the router to factory default. To connect to your ISP, you'll need to enter your account details (and any other specific information) provided to you by your ISP. You will also have to set a name and password for the wifi section of your router (if it has wifi) if you don't want it to be freely accessible by everyone within wifi range.
7/29/2021 11:33:41 AM •
Linksys...
Answered
on Jul 29, 2021
Why is my Linksys WRT54G wireless-g router not being recognized anymore?
just fixed one yesterday.
the power pack was no good.AC wall wart,
power green LED blinked endless. and the white logo, LED is dead..
a new pack fixed it.
also the wrong pack used, ! do not mix them up. oops.
first year 54G, v1 uses 5vdc pack.
at v2, and up all want to 12vdc pack,
bottom sticker on above failed was v6.
you said recognized, does that mean the 4 rear Ethernet wired jacks are dead, or just wifi dead.?
first the ethernet ports must work, or wifi is doomed.
2/18/2020 11:46:05 AM •
Linksys...
Answered
on Feb 18, 2020
How to fix Linksys router error 321 ?
Good day,
This might be of help .
Steps To Fix Linksys Router Error 321:-
Step1:- Check the Firewall Settings
To check the Firewall Settings is the first priority for the users. Then check the firewall settings of the computer/ Laptop, will be helpful to find the problem. If there is any firewall installed on the computer, so the users need to turn it OFF.During the process, the users ensure that the Local Area Connection on the computer is not disabled. The Local Area Connection should not have any static IP address assigned. If there is any then the users need to immediately set the IP address to automatic.
Method2:- Run the Installation CD Again:-
The users require trying to run the CD again and ensure when the CD runs, it will ask to connect the computer and the modem to the router with the cable. So the users will need to notice, that there all the lights lit up on the router. If it's not, then users will need to setup their router without the CD.
The users can get the instruction to setup router manually in the method 3.
Step3:- Try to Setup Router Without Installation CD
Setup Linksys Router without Installation CD is another best option for users in order to completely avoid the in order to fix Linksys Router Error 321.
Follow the below-given instruction to Setup Linksys Router without Installation CD:
First of all, connect the main computer to the Ethernet port on the router.
Then the users need to connect the modem to the Internet port on the router.
Now it's time to verify the status of the light that is blinking properly.
Next, users need to open the setup page of the Linksys Router and then change the Internet connection settings manually.
In the setup page of the Linksys Router, the users can change the settings of the router as per their needs.
Then the default IP address of many Linksys router is 192.168.1.1. And the default username and password would be an "admin".
Wait for a few minutes, when the main computer is able to access the Internet, so users need to create a wireless network for their wireless computers/devices.
or you can call them @ Toll Free 1-800-204-6959 that is Lynksys support.
2/3/2020 1:14:25 PM •
Linksys...
Answered
on Feb 03, 2020
How to Set Up Linksys WRT54G Wireless G Router
The vent actuators are bad. there should be two. one on each side. they are small toy like motors that open and close the vents from within to allow the hot air to blow by closing the vents to the a/c unit.
11/21/2019 5:05:43 AM •
Linksys...
Answered
on Nov 21, 2019
