20 Most Recent Ricoh MP5240A (RICOHMP5240A) DVD+RW Burner Questions & Answers
are the videos you are rying to burn store bought
Ricoh MP5240A... | Answered on Apr 08, 2018
if you mean IS NOT reading
you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
Ricoh MP5240A... | Answered on Jun 08, 2011
Is it just that one disk that the drive has problems with? If so, you may have a defective disk -- it may be scratched or damaged. You can try cleaning it and reinserting it to see if that helps.
If the drive won't read any disk, then you'll need to either get a new drive or get your drive repaired. You can try store-bought DVD drive cleaners, but these can be hit or miss.
Ricoh MP5240A... | Answered on Nov 16, 2010
depends on every type of dvd is diferent,you should try it couple times and you will get it right...
Ricoh MP5240A... | Answered on Apr 10, 2010
some drives can only read plus disks and not minus as well im afraid
Ricoh MP5240A... | Answered on Sep 27, 2007
this mean your device Cannot obtain IP address automatically from DHCP server.
check - DHCP Service is running on your network (most of the time with router)
check - your device is set as DHCP Client (from network settings)
or assign manual IP address to your Device
(with in same ip-range and subnet mask on your network)
Best of luck
Ricoh Computers... | Answered on Mar 02, 2019
https://printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20200&code=SC302
Ricoh Aficio 200 Error Codes
Ricoh Aficio 200 Error Codes Code:
Code
SC302
Description
Charge roller current leak
A charge roller current leak signal is detected.
Causes
• Charge roller damaged • Charge high voltage supply board defective • Poor connection of the PCU
Ricoh Computers... | Answered on Apr 18, 2018
Ricoh MP5240A (RICOHMP5240A) DVD+RW Burner Logo
8 questions posted
Top Ricoh Computers & Internet Experts
gggg
Shawn DuRee
Marvin
Marvin
Are you a Ricoh Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Ricoh Computers & Internet
Most Popular Question
drive read disk
  • Computers & Internet
