I suggest you connect the VGA cable from the computer to another monitor or a laptop, just to make sure that your monitor's back light is faulty. If it does show on the other monitor or laptop, then the back light is really faulty. And i suggest that you get a computer technician to open it up for you if you can not do it yourself. Or you can get a sharp-flat object and open the monitor starting from the bottom of the monitor working your way round to the top. You will notice finger-like structures that hold down the monitor covers together. Make sure you do not break any of those. When you open it, check on the circuit board where you connect the power cable. Check for any bulged or leaking capacitors. Capacitors have a job to hold down the power from the source long enough for your display. For faulty capacitors, the monitor will either remain black with the orange light blinking, or it will display for at least between 2 to 8 seconds and then goes black. Buy the same type of capacitors and replace the damaged ones. Please not the polarity as you replace the capacitors.. Good luck
Is this information from LCDPARTS.NET? I always remove the old lamp assembly and take an actual measurement of the lamp dimension before I place the order. The diameter is correct, but you should measure the length of the lamp, I know LCDPARTS.NET does give you some idea how to estimate the lamp size.
Are you sure that the lamp is bad, the common symptom of bad lamp is that it has pinkish light color wwen it first start up and slowly turning to normal white color light after warm up.
Manufacturer's Website: Go to the manufacturer's website (visit the official Samsung website in this case). Click on the support section, search your monitor model by product name or model number, and download your monitor model for the user manual. User manuals usually list codes and other relevant information.
User Manuals Online: Many people post user manuals online for all types of electronic devices and peripherals. You can search for your monitor and look for the user manual at sites such as ManualsLib, ManualsOnline, or Retrevo. Most of these sites will catalog user manuals for a wide variety of devices posted online by users and are normally free to access.
Physical User Manual: If you still have the original box or packaging with your monitor, there might be a copy of the user's manual in that box or enclosed. It might be in an actual printed booklet or perhaps just some links to online resources. Check under a section entitled 'Remote Control Codes' or 'Setup Instructions'.
Contact Samsung Support: If no luck finding it to download or to help you, there is contact support available, they should know where that information is, and be able to send it to you or refer you.
With these, you should be able to find the user manual for your Samsung 32" curved screen display and enter those codes.
ENGLISH ONLY please.
Samsung washing machine wf90f5e5u4w
Hello good afternoon, I want to ask for help, I have a faulty module and I wanted to ask if you have the electronic diagram for the Samsung DC92-01240C washing machine, the machine model wf90f5e5u4w, I would really appreciate it if you could, thank you. greetings Antonio Paulo
Sounds like the phone is on a contract with a different supplier.
Contact the original SIM supplier, EE, O2, Vodaphone etc and ask them to unblock the phone.
Question edited to add the further information.
Has to be in the manual? Did you pull the mains plug overnight?
That panel is called OSD (on screen display) and can be set to stay on for up to 200 seconds. Page 39 refers, and you can also reset it to factory defaults.
https://downloadcenter.samsung.com/content/UM/200803/20080329132905671_BN59-00716A-Eng.pdf
That sounds like a voice command problem for this Chicago, Illinois based channel. Refer to the station by its number on your subscription package, like "Alexa channel 1105 on tv".
https://www.google.com/search?q=wgn+-+tv
Samsunghttps://www.samsung.com > answer > ANS00087622
Amazon Alexa is now built-in on Samsung TVs and smart monitors! You can ask Alexa to change the channel, open apps, search for movies and shows, play music, ...
Tom's Guidehttps://www.tomsguide.com > How-to > TV
Apr 5, 2023 - Step 1: Set up your devices. First, make sure that both your Samsung TV and your Amazon Alexa device are set up and workings.
Can Alexa change TV channels? As long as you're using the TV's built-in tuner, you can use Alexa to change TV channels. Just say something like "Alexa, channel 7 on TV" or "Alexa, change channel to [channel name] on [TV name]."Nov 1, 2022
Plasma is old technology and it is 16 years old and made in Mexico, the worst place for quality control. It is time for a new one, or at least an upgrade. Or you can get a board kit and take a chance on fixing it.
