20 Most Recent Samsung HL-R5667W 56" HDTV Questions & Answers
Hello, It may be the new lamp is bad causing it to arc inside the lamp. contact who you bought the lamp from and see if they will replace it....tks
Samsung... | Answered on Nov 10, 2013
smbaker22,
Since this is a Samsung it is probably not your fan but your optical disc in the light engine. Samsungs have a known problem with this part. The replacement is not too difficult but does require good use of hand tools and someone who is concientious. If you think that you are up to the task I have a tip at http://www.fixya.com/support/r4160054-replace_color_wheel_in_dlp_projection_tv which will walk you through the process and show you where to get the best parts at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Samsung... | Answered on Oct 27, 2010
Purple spots means Bad Light Engine Part number is BP96-00822J Encompass Parts Has them for
$950.00 - $350.00 core price Part $600.00
1-800-638-3328 Lamp# BP96-01073A
Ballast Board# BP47-00027A
Samsung... | Answered on Jan 09, 2010
Hi my name is Eric,
I hope I can help you with your issue ,
Most likely your colorwheel is bad,
second possibility is the digital board.
Both are for a technician to install, you could do more damage poking around inside the TV.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Samsung... | Answered on Sep 27, 2009
You may have a colorwheel going bad. The bearings start going out and this is an indication of the failure. The colorwheel is located in the light engin e therefore you may want to get a qualified tech to look at it
Samsung... | Answered on Dec 17, 2008
remove the back cover u will see the fans one for the ballast and the other for the lamp
Samsung HL... | Answered on Jan 08, 2016
Sounds like a door switch is not making proper contact--or has been damaged. Check the lamp door switch and see if it is properly seated and the pin on the door is hitting the leaf of the switch.
Samsung HL... | Answered on Nov 26, 2014
You need a color wheel--common on these sets. Get a real phillips bulb and you should be set for awhile. The cheap generic bulbs are fine to get you through a few MONTHS....but NOT much longer. . An E22H-120/132 watt lamp is correct--and if you can replace just the bulb-(NOT hard at all to do) it will save you a LOT of money.
just from personal exp the easiest thing to do may fix or at least make it better. if u see puffed and leaky caps on power supply replace capacitors. if really dusty clean. both previously mentioned and both helped me. my tv was completely dead and replacing caps got it to power back up and work. it takes two trys to come on but works great so far. then i cleaned every nook and cranny with a small vacuum hose and different size/angle brushes that could be attached to hose. i only took out the psb board with caps and didnt touch anything in there that i could mess up. just cleaning helped enhance the colors. right now this is the best picture ive had on a tv and it was completly dead when i got it.
Samsung HL... | Answered on Jul 30, 2014
Check all your input cables & be sure they are snug on both ends, also check all your wiring connections inside the TV. you may have not gotten something back correctly or properly.
Samsung HL... | Answered on Jul 25, 2014
EURO STAR LCD TV 32" BLANK PROBLEM
Samsung HL... | Answered on Jan 23, 2014
(Please check your model number - it appears to be incorrect, I believe it's HL-S5687W)
1) How old is the lamp? (how many hours on it)
2) Is the lamp an original equipment lamp, or aftermarket?
It's either the Lamp itself (it's not common for a sudden reduction in brightness), -or- the Lamp Ballast has gone bad. This is the power source for the Lamp, and although they usually die completely when they do go, sometimes they will act just as you have described... they fail into a "low power" mode.
If the lamp IS an original mfr lamp, and if it's nowhere close to being near "end of life", then I'd say it's likely the Ballast.
Prices for the original Samsung lamp run around $100 onamazon and others.
The Ballast p/n BP47-00037A has a cost of around $50 to $100 online.
Google those p/n in "Shopping"
The Ballast can be replaced without great knowledge, but will require some dis-assembly, and CARE.
WARNING - Dangerous, and even lethal voltages are present inside your TV set. Do not attempt this unless you are trained in these kinds of repairs. Leave the TV unplugged for several hours (or preferably a full day) before attempting such repairs.
Samsung HL... | Answered on Jan 12, 2013
as far as I know that set does not have a lamp timer to reset.
Samsung HL... | Answered on Sep 04, 2012
Samsung HL-R5667W 56" HDTV Logo
6 questions posted
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
View Most Popular
HL Samsung
  • HL Samsung
Most Popular Question
samsung dlp hl r5667w not turning
  • Televison & Video
