Pre-recorded and DVD -RW discs have to be loaded several times before they are accepted (I can here...
(More)
Pre-recorded and DVD -RW discs have to be loaded several times before they are accepted (I can here an irritating clicking noise when this happens sometimes too, and even then with some of them it is potluck. When i have recorded something, then ejected the disc, when I reload the disc to watch it it asks to initialize the disc when it already has been initialiized. This means if I want to use the disc again I have to initialize it and that in turn wipes the contents. What's the matter with it? I'm thinking of buying a more reliable player but would still like to kn ow what is going on........
I have 120 VAC down stream of the fuse, but my HD960 acts just like the fuse is blown (or like it's...
(More)
I have 120 VAC down stream of the fuse, but my HD960 acts just like the fuse is blown (or like it's not even plugged in). Worked great up until now. Naturally, everything inside looks super - no sign of anything getting hot.
I just bought a 960 to go with my samsung hp-5053 plasma display. I have tried a few recent dvd'd in...
(More)
I just bought a 960 to go with my samsung hp-5053 plasma display. I have tried a few recent dvd'd in the dvd player but everything is poor quality. Even the setup menu copy is jagged looking. I have tried several things but don't seem to ahve the answer. I used the hdmi cable supplied with the dvd. Any ideas?
Received my Samsung HD960 in the mail yesterday. Enjoyed it last night, but this morning, no power,...
(More)
Received my Samsung HD960 in the mail yesterday. Enjoyed it last night, but this morning, no power, won't turn on. I'd otherwise just return it to Circuit City, but there is a rental disc in there and wondering if there is solution to get power back.
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
