20 Most Recent
Samsung LN-S4092D 40 in. LCD HDTV Questions & Answers
Horizontal multicolored lines appearing
Open up the TV and unplug and re-plug the connectors to the circuit boards. This is most often caused by a poor connection of the circuit board connectors.
3/25/2017 1:32:26 AM •
Samsung...
Answered
on Mar 25, 2017
Factory reset
To make a factory reset, you have to enter its service mode option.
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.Service mode entry, adjust and exit procedure to many brand TVs are given in detail.
10/28/2013 5:44:25 AM •
Samsung...
Answered
on Oct 28, 2013
Weak or no signal message
- Since my problem (Samsung/Comcast) began with a channel selection button pushed on the TV remote when it should have been pushed on the cable remote, I figured the problem lay with the TV. Although I was getting the "weak or no signal" msg., the actual signal strength bar graphic showed it to be strong. Disconnecting did no good. I surmised that the TV was simply not recognizing the box.
- I looked at the manual for my Samsung 750 model.
- Page 20 discussed "Selecting the source". I accessed the TV menu and selected "Input", then chose the "HD..." item from the highlighted list. Voila! My tv works again.
12/22/2012 6:13:27 PM •
Samsung...
Answered
on Dec 22, 2012
Samsung ln-s4092d no red tint
There are a few things that can cause this. Your t-con board, the signal board or the screen itself. The most likelly and cheapest would be the t-con board. This is the board that transfers your picture from the signal board to your screen. You would have to open up your tv and get the part number from the board itself.You can get get parts for this tv at www.interliquidparts.com
11/26/2011 9:42:05 PM •
Samsung...
Answered
on Nov 26, 2011
Samsung 40" tv won't turn on
i had the same problem, you'll have to call the samsung service center. You TV's part which looks after the voltage connectivity has failed. This majorly happens due to voltage fluctuations. The part will cost around Rs. 2800 and service charges will be applied by the company.
11/26/2011 8:19:48 PM •
Samsung...
Answered
on Nov 26, 2011
LN-S4092D 40 in Samsung tv.
Please take out main board and power supply of set 1 and 2 and test them in set 3 as it is still working, swap set 1 and 2 boards in set 3 just to narrow down problem.
Set 3 got lcd panel (screen) problem as it is showing white vertical line and lcd panel is very expensive part that would cost you approx new tv price so I would recommend to utilize its boards to fix/ repair set 1 and 2
Hope this will help you.
Thanks.
3/19/2011 7:54:16 PM •
Samsung...
Answered
on Mar 19, 2011
Do we need a voltage
no that is biggest scam now for consumer electronics that and over priced HDMI cables
just make sure you have some type of surge protector to protct unit
3/13/2011 2:32:55 PM •
Samsung...
Answered
on Mar 13, 2011
How do I access the service menu of my Samsung
with the TV off. press "Mute" "1" , "8" , "2" , "Power" on the remote (one at a time). But be careful when in there, you can change setting to keep your TV from ever working again.
3/9/2011 12:19:32 AM •
Samsung...
Answered
on Mar 09, 2011
I have a samsung 40
The fault you have mentioned is caused by faulty capacitors usually those on the Power supply board and/or SSB main board. I would suggest that you take a good look at the board and look for capacitors with swollen or cracked tops. The problem is caused by the caps unable to sustain their charge discharge cycle for a long time due to lost or corrupt electrolyte.
12/18/2010 7:38:37 PM •
Samsung...
Answered
on Dec 18, 2010
No picture and just sound
I would have to say the inverter(The board that lights up the screen) is bad.Thank You very much!
Tyler
12/10/2010 10:45:49 PM •
Samsung...
Answered
on Dec 10, 2010
My two year old son pushed a button on the remote
try going to the tv itself and push the source/input button. you should go to the correct source to get your picture back. try looking for the input or source button on the remote as well. that should do the trick -gab
10/18/2010 3:58:10 AM •
Samsung...
Answered
on Oct 18, 2010
Do i need a voltage
try to use a ups it is more reliable than avr bec ups has a avr to
10/9/2010 1:52:50 PM •
Samsung...
Answered
on Oct 09, 2010
