20 Most Recent Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player Questions & Answers
Here is the user manual for your player if you need it; http://downloadcenter.samsung.com/content/UM/200601/20060124115711375_YPZ5-USA-ENGLISH-0.0.pdf Page 18 states that you can only sync with wmp 10, there is no alternative software that will do the job. Hope this helps :)
Samsung Yepp... | Answered on Mar 26, 2013
got a chance to check out Samsung's new lineup of gadgets and gizmos this week and was very impressed with their upcoming Samsung MM-X5 MP3 Player Docking Station. It plays content from MP3 players, including any generation Apple iPod as well as CDs. The device has a built-in USB port that allows for instant music file playback from a standard USB memory drive as well, so if you're too lazy to put your music on your player you can just plug in your flash drive.
The MM-X5 comes in Samsung's token piano finish black and unlike some of the more simple docks on the market features a built-in display and an alarm that lets consumers select songs to wake up to. It features built-in 20 Watt speakers (10 Watts each), combined with Samsung's Digital Natural Sound engine technology. Available this October for $199.
View 2 Photos ›
Samsung Yepp... | Answered on Jun 09, 2010
This might help getting it connected to the computer.
UMS mode allows the Z5 to interface to the computer as if it were a removable hard drive. You can then use Windows File Explorer to manage the files in the Z5.
To get into UMS mode, connect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
If you upgrade to the new firmware, you have the option of making it always connect in UMS mode.
The steps to install the latest firmware are:
(1) Download version 2.37 or newest of the Z5 firmware http://www.samsung.com.
(2) Unzip it to get the file named "Z5Update.dat".
(3) Disconnect the Z5 from the USB port.
(4) Reconnect the Z5 to the USB port while simultaneously holding down the "return" button (the top of the square keypad) while connecting. This will put the player into UMS mode for that connection period only.
(5) Open a File Explorer window, and find the YP-Z5 device.
(6) At this point, make sure the Z5 is fully charged and has at least 30MBytes of free space.
(7) Copy the file "Z5Update.dat" to the root directory of the YP-Z5 device.
(8) Now disconnect the Z5 from the USB port.
(9) The Z5 will display the option to upgrade to the new software, or to cancel.
(10) Select "Upgrade". This will power off the Z5.
(11) Connect the USB cable to the Z5. Now it will upgrade the firmware under USB power. DO NOT DISCONNECT THE USB UNTIL THE UPGRADE FINISHES. After finishing the upgrade, new firmware will be started automatically.
(12) Check the version information in the "Settings > System Info > Version" tab.
Now you can turn on the UMS only option.
Settings / System Info / UMS Only = On
Samsung Yepp... | Answered on Mar 01, 2010
I don't understand people, why pay for a docking station... when all you need is a connector from you headphone input on the player to your stereo or boom-box which has an auxiliary input. The plug you can get at any store and it only cost about 3 - 10 dollars. The plug has the same end you use on your headphones and the other end is the same as the input connectors for your stereo unit. That end would have the 2 connectors (usually red and white) that you use when connecting units to your stereo's auxiliary input. Connect and listen to your music.
Or you can buy and fm transmitter for your player and listen to your music via a fm radio station. Cost about $20 or more... depending on the name brand.
Samsung Yepp... | Answered on Dec 14, 2009
Well First of all you can install the driver to connect your phone, if you do not have the driver then download it from the below link -
http://www.nodevice.com/driver/company/Samsung/MP3_Player/page3.html
If further you have the same problem then upgrade the firmware of your mobile, check the below link to know how to upgrade the firmware -
http://www.planetamd64.com/lofiversion/index.php?t26033.html
post further comments for more help or information....
Good Luck!!
Thanks
Samsung Yepp... | Answered on Nov 28, 2009
did u get some water on it too like me?
Samsung Yepp... | Answered on May 02, 2009
I held the off button for 20 seconds, player turned off, then I turned it on and it works fine - holding the button for 20 seconds is key
Samsung Yepp... | Answered on May 01, 2009
go onto music and onto sync then connect mp3
Samsung Yepp... | Answered on Apr 20, 2009
see the reset button on the bottom? press it. mite have to use a sharp pencil or a pin.
Samsung Yepp... | Answered on Apr 14, 2009
Hi I am having a problem to with the MTP device. Bottom right corner of my screen has the window that says found new hardware...MTP device. I can not close out the window because it keeps coming back. Then I hear this like bubble sound when it's on the screen. Any suggestions? I think its for my new phone that I downloaded on the laptop. I am going to uninstall it and reinstall it and see what happens. Any other suggestions please let me know thanks...
Samsung Yepp... | Answered on Mar 08, 2009
push the reset button
Samsung Yepp... | Answered on Oct 10, 2008
It's not supporting mpg movies. You need to convert it to .amv then you can show it on the Player.
Samsung Yepp... | Answered on May 21, 2008
you cant't charge the mp3 like that because samsung and ipod are tow diferrent companies and if you could you might enup frying your mp3 so try buyng the car charger for the yp-z5.
Samsung Yepp... | Answered on Apr 18, 2008
use a small paper clip and just to the side of the connection for the usb port on the player, you will see a little hole.... only large enough for a small needle...or a small paper clip end.. stick it in there and push one time.. and you will either feel it click or hear a click and your player screen should go blank.. you just reset the program in your player and this should solve your problem.
Samsung Yepp... | Answered on Feb 03, 2008
Try reseting the player. It might not work all the time, but this was the first time my down scroll ever locked up on me, and the reset button fixed the problem. It might just be a temporary solution, but at least it's something.
Samsung Yepp... | Answered on Feb 01, 2008
Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player Logo
48 questions posted
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
YP Samsung
  • YP Samsung
Most Popular Question
docking station mp3 players
  • Audio Players & Recorders
