20 Most Recent
SanDisk Sansa m200 (2 GB) MP3 Player Questions & Answers
Usb not detecting
Please check your USB with another player and confirm that it is not detecting. If so the fault is with the memory . It is possible that the ipod had detected some faulty files and so has errors within which can be a reason. Try and reset and see if the ipod resumes. if the ipod is still not detected then it is possible that there is errors within. allow battery to drain off fully and see if the fault changes.
How do I clear the songs from mySanDisk
Connect to supplies USB cable to your MP3 player and connect the other end to the USB port on your computer. The computer will see the MP3 player as an external storage device, you can then select the mp3 music files you want to delete (they may be in a music folder) then press the Delete key on your computer just like any unwanted files on your computer.
I couldn't find Sansa on my computer when I connect with USB cable!
Go into the device manager by right clicking on my computer, hitting manage, and highlighting device manager.
Expand the usb devices section and see if there are any unknown devices listed.
Hit view Show hidden devices if you cant find anything.
Remove anything that says unknown device.
Take out the device from the computer, install the most recent software from their website.
Connect the device back.
Can't sync
Try sansa with a diffrent XP service pack or Use Winamp ( Newest version ) and use it's syncing option
About songs
go to my computer click on your mp3 player icon it could possibly under drive f: open it up click on the song you want to delete go to the left hand side of the screen and there will be a button saying delete from device click it will delete it.
you could also go to the windows media player and click syncronize on the right hand side their should be column with the items of music on it click the song you want to delete and then right click it. it will say delete and then delete it
from jacob
EDIT** Sometimes going into your computer and finding the drive your music is in doesn't work. You cand delete it all you want and it reappears. If this happens or you just want ALL files on your device erased go to My computer>(drive your device is plugged into)right click it>Format it ... But this is another alternative that will help if the other 2 ways don't work.
dont forget to rate me......
good luck....
How to delete songs?
Deleting Files,Pictures,Videos,Audio
Books, etc. from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal
Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on
"Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that
you do not want this will highlight the files/songs you do not want,
release, right click and then click on "Delete"
Now your mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Good Luck,
I hope this helps
Please rate me,
Thank You
Memory problem
Hello J.kam
Use disk management to format it.
At times we use other format like fat or fat32.
Try this.
Regards
Uttam
I am trying to delete songs on my playlist. I
connect your sansa to the computer and via usb cord check computer the hardrive letter e,f,d, whatever right click that letter and then format. this will delete all the songs. or you could open windows media player click sync and then drag and drop songs from your computer to your sansa or visa versa.
Some of the songs I have in my mp3 players skips.
it might be the song format which u can see from i tunes and configurate it from a mac program that is called garage band or u can also get one for the pc maybe is also ur mp3 configuration which u can configurate also from the commputer
My computer can`t read the MP3 player...What
Do a google search and see if you can find a free download of your manual. Had you connected your player before? Could your computer read your player before?
My computer doesn't recognize my MP3 But, I can connect it like it is an external drive with no problem.
