20 Most Recent SMC EZ Connect g SMCWEBT-G Questions & Answers
I'm unsure of the exact part number here but using the model number I checked the manual. This looks like it's just an access point which extends a current network you have. If you only have your laptop, this device and your internet modem it may not give you the wireless connectivity you're looking for. On a normal setup you would plug your modem into a router, plug your laptop into the router and set it up with all your DSL/Cable connection information as well as wireless on/off. You can then unplug from the router and continue life. with this one it's only connecting to an existing setup (another router or another wireless network) and extending it.
If you are looking for a solution to give you a router that connects to your modem and gives you wireless or adding multiple devices on a single connection I would recommend returning this and getting an all-in-one router such as this: http://homestore.cisco.com/en-us/Routers/Linksys-E1000-Wirelessn-router_stcVVproductId97826160VVcatId551966VVviewprod.htm?icid=linksys-specs-e1000-learnmore-btn&src2=linksys-specs-e1000-learnmore-btn
SMC EZ Connect g... | Answered on Mar 07, 2011
Make sure there is not same ip addreses in router and computer.
Enable DHCP server in router configuration page.
For that connect your router t ocomputer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then you can see configuration page of router.
Then go to advanced option and find DHCP enable DHCP.
Then save settings and restart router.
If still not works then RESET router.
For that RESET button is in back panel of router press it for 10 seconds.
Then configura your router with above link.
Let me know if you need further assistance.
Thanks.
SMC EZ Connect g... | Answered on Nov 04, 2009
It may because you have a mac filter on. If so you can correct this by connecting to the router then in a Internet explorer type 192.168.1.1 and you should have a configure screen available then either disable the mac filter or enter the other mac adresses. Good Luck
SMC EZ Connect g... | Answered on Jun 26, 2009
you make a device into ap mode you can get it
SMC EZ Connect g... | Answered on Jun 12, 2008
update the firmware of the all device
SMC EZ Connect g... | Answered on Jun 11, 2008
There suppose to be a reset button on it mainly on the back of it
SMC Computers &... | Answered on Apr 23, 2019
different USB port. There are usually 3 or 4 of them. If you can, format the USB drive (if you have nothing on it or already have copies of what is on it). It will take 10 seconds, but will wipe all data. It should be recognized then.
SMC Computers &... | Answered on Apr 11, 2019
look for a windows xp driver file on the included program compact disc that may need to be installed before you use the included program.
SMC Computers &... | Answered on Mar 05, 2018
Ask a question.
SMC Computers &... | Answered on Mar 09, 2015
The question doesn't make sense but I'll assume you mean,
How fast is it.
It's set by the IEEE standards.
IEEE802.11
Look for eg. 802.11n
The letter at the end will give you an idea of it's speed.
N is current standard
AC is the most up to date
a & b are old standards
See http://en.wikipedia.org/wiki/IEEE_802.11
Cheers
Trevor
SMC Computers &... | Answered on Sep 09, 2014
Hi,efault
U need to isolate the problem first.
Check if the wireless drops on all devices or only on one particular device.
If it occurs on only one particular device,the problem is with the wireless adapter of that advice..
If it happens on all the devices then the problem is with wireless router
For that
Check for the wireless interference . Avoid having cordless phone base near the router.
Also try changing the wireless channel of the router To 1,6,11
U can do this by logging on to the router set up page of your router
To Find the address of your router,type ipconfig /all in the command prompt.Look for the Default gateway address and type it in the address bar.U will find your Router set up page..and u can change the wireless channel there
SMC Computers &... | Answered on May 14, 2014
SMC EZ Connect g SMCWEBT-G Logo
Popular Tags
8 questions posted
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • SMC Computers & Internet
Most Popular Question
bought smc wireless router tries
  • Computers & Internet
