20 Most Recent Sony Ericsson HBH-610a (Auto Pairing) Bluetooth Headset W550i,K750i,W800i,W900i Headset Questions & Answers
this for sony ericson, not for nokia
Sony Ericsson... | Answered on Jan 13, 2011
First you have to check if the bluetooth is universal or works with your mobile phone; if it does then it could be that your phone has been set not to be visible to any device. You can change that by going to the bluetooth settings or option and change the visibility setting.
Sony Ericsson... | Answered on Jun 03, 2010
try charging it for 24 hours to reset it.
figure out how to open it then take the battery out then put in the new one duh
Sony Ericsson... | Answered on May 02, 2010
Deleting files from your memory card is not enough. Usually the files received threw bluetooth will stored to phone memory and then prompted to store somewhere else by the user. So delete/move unwanted files from phone memory to memory card. Delete all the messages stored in your SIM card too.
Sony Ericsson... | Answered on Jul 29, 2009
when a file is sent to the folder named other, it usually means the fone cannot play the desired file.
thank you
RC
Winchester
Sony Ericsson... | Answered on Jun 23, 2009
Yes. I have this old trusty combination and it works perfectly with auto-pairing. The phone also supports bluetooth v2.0 which means good sound quality and excellent link reliability.
Check out the instructions here: http://www.sonyericsson.com/cws/support/accessories/detailed/userguide/hbh-610a?lc=en&cc=us
Sony Ericsson... | Answered on Apr 15, 2009
1)Turn on the blue tooth headset
2)Turn on bluetooth on your phone and search for devices.
3)When it finds the device select it and click connect.
Thats all.
Sony Ericsson... | Answered on Feb 24, 2009
turn the bluetooth on wait 10 seconds after the bluetooth has turned on. after it has turned on hold the (+) & (-) volume buttons at the same time for about 5 seconds. the light on the outside will then start to flash green and red, and it is ready to pair to your phone.
Sony Ericsson... | Answered on Jan 19, 2009
Did you check the headset'sbattery. May be its drained and needs to be replaced.
Sony Ericsson... | Answered on Sep 02, 2008
Hi, The way that I paired my device is by pressing and holding the two volume buttons simultaneously for about 5 seconds, until the red and green lights began to appear. Then, i just 'refreshed' my bluetooth search for devices, and it discovered it, and was able to pair it up. Hopefully, this is useful
Sony Ericsson... | Answered on Jul 20, 2008
if any one got the solution pleae tell me too hahaha
Sony Ericsson... | Answered on Jun 20, 2008
try taking out the memorystick.
Sony Ericsson... | Answered on Mar 14, 2008
Ensure the battery has a good charge on it, and attempt to turn the item on while plugged in to the charger. If this does not work, I would return it for a replacement.
Sony Ericsson... | Answered on Jun 09, 2007
Hey i am having the same problem with my k750i and i have also done everything you ve done, then the problem should be with the phones.
Sony Ericsson... | Answered on May 26, 2007
the phone software is currupted so you need to take to a phone stall/shop and get it flashed it will cost but not too much.
Sony Ericsson... | Answered on Apr 26, 2007
I took my Back of my k750i to put a new cover and back on and now the camera is not working. THe phone is not picking it up. I think theres a connection at the back but i cant find it! plz help.
Sony Ericsson... | Answered on Apr 03, 2007
The wire to headsets can get damaged (usually not visible from the outside, as the wires inside the covering can be very delicate, to keep the size of the wire down) from throwing them in the pocket, purse, etc. Try a set from a friend to make sure the device is still working itself.
Sony Ericsson... | Answered on Dec 02, 2017
Sony Ericsson HBH-610a (Auto Pairing) Bluetooth Headset W550i,K750i,W800i,W900i Headset Logo
Popular Tags
31 questions posted
Top Sony Ericsson Radio Communications Experts
Håkan Sterner
yobo007
yobo007
Jay Finke
Jay Finke
Are you a Sony Ericsson Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Ericsson Radio Communications
Most Popular Question
pair k750i hbh610a
  • Radio Communications
