20 Most Recent Sprint SP-708 Phone Questions & Answers
The answering machine will pick up with the
hi I need puk code for 7795633373
11/5/2013 4:27:23 AM • Sprint SP-708... • Answered on Nov 05, 2013
I would like to replace my old Sprint phone - land line, corded # SP 603
I see no question here?
3/9/2018 9:46:04 PM • Sprint Lands... • Answered on Mar 09, 2018
0answers
When someone call my phone
Try and make a call out; if that works, then contact Sprint directly, as there must be some sort of issue on their end about not having your number configured correctly.
If you can't call out or get calls, check to make sure you have signal (duh). Next, turn off your phone and make sure that your SIM card is inserted correctly by removing the cover to the battery compartment of your phone and looking for a card that looks like this: benharris5.jpg If you can't find one of these in the phone, check your original packaging for such a card; it must be inserted correctly in order for the phone to do anything. (This card essentially tells the phone what phone number it needs to listen to and on what network; without it, it has no idea what to do.) If you can't find a card, contact Sprint and they will send you a new one for free/cheap.
If both of those fail, either (a) you have a defective phone, or (b) Sprint hasn't activated your phone. In either case, you'll need to contact someone from Sprint about the problem. I suggest going to your local Sprint store and asking them for help; usually you can get things done a lot faster in person. If you can't do that, try contacting Sprint directly.
Contact info for Sprint: 888-211-4727 http://www.sprint.com/contactus/
3/1/2011 2:12:11 AM • Sprint Lands... • Answered on Mar 01, 2011
My phone will not ring.I
go into settings or profile according to what type of phone you have and select "normal"
2/12/2011 12:36:38 AM • Sprint Lands... • Answered on Feb 12, 2011
My grandaughter has sprint with
kajeet is not technically Sprint, it just operates on the Sprint network. You should call kajeet customer care and see if they can help you. 1-866-4kajeet
Also.....I don't think it's very safe for you to publish your phone numbers and address on a public forum on the internet. You might want to take those down as anyone can now call your grandaughter and we all know where you live. Safety first!!
10/25/2010 2:28:23 PM • Sprint Lands... • Answered on Oct 25, 2010
2answers
My computer dosnt see my phone when i plug it in
you may have to change your settings or the firewall may be blocking it
3/16/2010 9:44:29 PM • Sprint Lands... • Answered on Mar 16, 2010
How do i make my music to ringtones
click here for instructions - ringtones
2/28/2010 12:35:59 AM • Sprint Lands... • Answered on Feb 28, 2010
Stuck on looking for service
You should contact Sprint/Nextel for assistance.
10/17/2009 7:40:11 AM • Sprint Lands... • Answered on Oct 17, 2009
My cenrto phone is off wont turn on
try charging it
8/2/2009 1:04:38 AM • Sprint Lands... • Answered on Aug 02, 2009
Answers that resolve the problems. Not opinions.......we all have those.
Hello again Mike. and now you are in the category 'Landline Phones;' rather than Cell Phones, so perhaps it is a phone after all. Contact the cellphone carrier, or but a new Landline Phone. ..
4/24/2024 12:09:17 AM • Lands Phones • Answered 8 hours ago
I need a manual for a speakerphone 210 with a 13 memory an lcd
google speakerphone 210 manual for choices.
4/5/2024 12:49:29 AM • Lands Phones • Answered on Apr 05, 2024
How can I set up favourites on Eircom landline please?
Question edited for clarity. Question moved from Video Consoles category. Trying to find a manual. Are you sure that model is correct? Eircom should give you a manual PDF. https://www.google.com/search?q=Eircom+perform+100+manual and https://www.google.com/search?q=Eircom+perform+100 ..
3/26/2024 3:10:48 AM • Lands Phones • Answered on Mar 26, 2024
What is direct marketing?
Hello
Direct marketing is a sometimes controversial sales method by which advertisers approach potential customers directly with products or services. The most common forms of direct marketing are telephone sales, solicited or unsolicited emails, catalogs, leaflets, brochures and coupons. Successful direct marketing also involves compiling and maintaining a large database of personal information about potential customers and clients. These databases are often sold or shared with other direct marketing companies.
for more information visit http://www.wisegeek.com/what-is-direct-marketing.htm
Hope this helps if so do rate the solution
3/21/2024 10:02:08 AM • Lands Phones • Answered on Mar 21, 2024
Main Handset saying Out of Range, Other 2 alright tried re-registering it but no luck. Asked for a PIN number but I don't remember putting one in when I first set it up.
Good question but no 'make model (what it is). Base units have an antenna, make sure it is extended. Make sure the batteries in the satellite hand sets are good as they send out the signal to the base unit to be 'in range'. Not sure about the PIN request, refer to the manual. They are all online. Google make model manual ..
2/28/2024 6:57:13 PM • Lands Phones • Answered on Feb 28, 2024
SONIM XP 3800 VOICEMAIL INDICATOR STAYS ON BUT,NO MESSAGES=? TRIED POWERING OFF-PROBLEM STARTED 2/WEEKS AGO.
1. First, try resetting your phone by powering it off completely and then turning it back on after a few seconds. This can sometimes resolve minor software glitches.
2. If the problem persists, you can try contacting your mobile service provider and ask them to reset your voicemail on their end. They might be able to resolve the issue from their system.
3. Another option is to manually check your voicemail and listen to any existing messages. Sometimes, even if you've listened to a message, the indicator might stay on. By checking your voicemail and ensuring there are no unread messages, it might help clear the indicator.
If none of these steps work, it could be a more complex issue that might require technical support from Sonim or your mobile service provider. They should be able to provide further assistance. Let me know if there's anything else I can help with!
2/5/2024 4:27:32 AM • Lands Phones • Answered on Feb 05, 2024
Why is this section of the forum titled Lands Phones? The accepted label of Landline Phone has been used for decades. Why the plural form of Land?
Because when the site was started June 2005, it was staffed by IT kids adding categories on the fly as questions were being added. You can't expect youngsters to know basic English Language. The standard of written English in questions on this website is quite frankly, appalling. I edit nearly every question I answer, and many that I don't answer. I will see if I can get it changed. I have requested it and our other Admin said he also wondered why?..
1/30/2024 9:55:07 PM • Lands Phones • Answered on Jan 30, 2024
Lands Phones Logo
Popular Tags
1 questions posted
Top Sprint Lands Phones Experts
k24674
Are you a Sprint Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Sprint Lands Phones
  • Sprint Lands Phones
Most Popular Question
  • Lands Phones
