No powerThere is no power at all, I checked the power switch on main PSU, fuse ok, main power supply ok. On the second power...
2 Solutions
COLOUR MISMATCHINGI have one toshiba projector,model t90.when the system connected to the pc,all colours are coming.but colours are...
1 Solution
fuzzy imagesI use my projector to reflect on the Smartboard in my classroom. It is now projecting some fuzzy colors in the bottom...
1 Solution
View All
Specifications
Key Features
Image Brightness2000 ANSI lumens
Image Aspect Ratio4:3 (Standard) Analog Video FormatNTSC · PAL · SECAM Image Size (Diagonal)24.6 in. - 246 in. Screen Distance3.9 ft. - 32.8 ft. Color Support24-bit (16.7M colors) Max Resolution (Interpolated)1600 x 1200 (UXGA) Synchronization Range Horizontal15 - 93 kHz Synchronization Range Vertical50 - 85 Hz HDTV Formats720p · 1080i · 480p · 576p · 480i · 576i
Technical Features
Audio OutputSpeaker(s) · 3.5 mm Mini Jack Front Panel ControlsKeypad
Interfaces
InterfaceRS232C (mini DIN-8 pin) · USB Video Input15 Pin D-Sub VGA · Composite Video
Lamp
Light Source Life2000 Hours
Other Features
Special FeaturesKeystone Correction Projection MethodRear · Front · Ceiling
Dimensions
Toshiba Contact Information
Main support number800-457-7777
Sponsored Links
