Toshiba TDP-S9E Multimedia Projector
Problems with Toshiba TDP-S9E Multimedia Projector?
Troubleshooting and Support
Solved Problems for Toshiba TDP-S9E Multimedia Projector RSS Feed Post a New Problem
LCD shutting off automatically
I use a Benq LCD projector to give powerpoint presentations. Lately the projector shuts down shortly after powering up....
1 Solution
paint your website area by giving...
how can you paint your website area by giving coordinates ?
1 Solution
In Focus X2 projector won't display...
In Focus X2 projector won't display welcome screen. It turns on, the fan goes on too and the green light is steady. I...
1 Solution
White vertical line in the center of...
We have had our X2 for about 3.5 years and not changed the bulb out. Within the last two weeks, a vwrtical white line,...
1 Solution
InFoucus LP500 Projector
My InFocus LP500 projector has a pinkest image when connected to the Dell C840 laptop. I have update the display driver...
1 Solution
SMALL ICON APPEARS ON THE SCREEN (TOP...
USUNG A TOSHIBA PROJECTOR MODEL TLP X3000 AND WHEN WE USE THE REMOTE TO MAKE THE PROJECTORED IMAGE LARGER A SMALL X IN...
1 Solution
Projector- Sharp XR-20X won't start up
We have a fairly new projector- a Sharp multimedia projector, model xr-20x, that won't start up. We've gone through all...
1 Solution
Unsolved Support Problems
Unsolved Problems for Toshiba TDP-S9E Multimedia Projector RSS Feed Post a New Problem
I have a Toshiba TPD - S9E Lamp indicator...
I plug the unit in and the power led blinks but no fan and no lamp led
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
TypeDLP Projector
Form FactorPortable
Display TechnologyDLP
Image Brightness1500 ANSI lumens
Contrast Ratio2000:1
Image Aspect Ratio4:3 (Standard)
Analog Video FormatNTSC · PAL · SECAM
Image Size (Diagonal)30 in. - 275 in.
Screen Distance3.9 ft. - 32.8 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1600 x 1200 (UXGA)
Synchronization Range Horizontal31 - 79 kHz
Synchronization Range Vertical50 - 85 Hz
HDTV Formats720p · 1080i · 480p · 576p · 480i · 576i
Technical Features
Audio OutputSpeaker(s)
Operation Noise32 dB
Front Panel ControlsKeypad
Interfaces
InterfaceUSB
Video Input15 Pin D-Sub VGA · 4 Pin - Mini DIN (S-Video) · Composite Video
Lamp
Light Source Life2000 Hours
Other Features
Special FeaturesKeystone Correction
Speakers Output2 W
Projection MethodRear · Front · Ceiling
Warranty
Warranty3 Years, 90 Days On Lamp
Dimensions
Depth7.87 in.
Height3.46 in.
Width10.08 in.
Weight5.28 lb.
Toshiba Contact Information
Main support number800-457-7777
Sponsored Links
Loading problems.
Top Experts
Ask Me
Marrie Wiz
15 solutions
Ask Me
3bachelor Wiz
7 solutions
Ask Me
Arius Wiz
2 solutions
Repair Service
Find Multimedia Pro. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
