FixYa.com
Toshiba TLPS10E Multimedia Projector
All Products > Toshiba > Multimedia Projectors
Problems with Toshiba TLPS10E Multimedia Projector?
Search inside Toshiba TLPS10E Multimedia Projector Knowledgebase
Troubleshooting and Support
Solved Problems for Toshiba TLPS10E Multimedia Projector RSS Feed Post a New Problem
How do I redirect the output of my PC...
How do I redirect the output of my PC laptop to the projector?
1 Solution
Projection Problem with Toshiba TLP 261
When the projector is turned on, it displays the default screen. In the lower left corner the display is red. Adjusting...
1 Solution
Epson EMP-82e locked out
One of our staff turned off the projectors power. He then proceeded to input the wrong security code and the projector...
1 Solution
Connecting Sky TV to my projector
I am finding it hard to connect my sky tv to my projector, which cable do i need.
2 Solutions
green tint
I just purchased an epson powerlight s1. All the highlights are green. I tried adjusting the color and tint, but nothing...
1 Solution
my problem is that the Image is not...
my problem is that the Image is not stable, on my projector, any suggestions?
1 Solution
CONNECT CABLE TO MY PROJECTOR
HOW DO I HOOK MY CABLE UP TO MY MITSUBISHI DLP PROJECTOR MODEL HC1500
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Toshiba TLPS10E Multimedia Projector RSS Feed Post a New Problem
No picture at all
With a toshiba tdp-d2 The warning lights indicate the lamp is bad about 1 minute after power up, so we replaced the...
Post a Solution
Toshiba LCD projector - TLPS10E: cycles...
The projector mimics a lamp related problem, have tried it with a new lamp but the cycling problem persists. I need...
Post a Solution
partial image
When I hook up projector to a laptop or computer, I can't see the full computer screen on projector screen. How do I get...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeLCD Projector
Form FactorPortable
Display TechnologyTFT Active Matrix
Image Brightness1200 ANSI lumens
Image Aspect Ratio4:3 (Standard) · 16:9 (Wide Screen)
Analog Video FormatNTSC · PAL · SECAM
Image Size (Diagonal)40 in. - 300 in.
Screen Distance5 ft. - 38.03 ft.
Color Support24-bit (16.7M colors)
Technical Features
Audio OutputSpeaker(s)
Dimensions
Depth8.11 in.
Height3.31 in.
Width11.93 in.
Weight4.85 lb.
Toshiba Contact Information
Main support number800-457-7777
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
