Toshiba TDP T 91AI have 3 out of 30 projectors TDP T 91A that very quickly switch to overheating and shut down. These machines started...
1 Solution
projectorsI have an optoma hd70 bought new. It only has 170 hours of lamp life used. When i turn it on thin black verticle lines...
1 Solution
fuzzy imagesI use my projector to reflect on the Smartboard in my classroom. It is now projecting some fuzzy colors in the bottom...
1 Solution
View All
Specifications
Key Features
Image Brightness2200 ANSI lumens
Image Aspect Ratio4:3 (Standard) Analog Video FormatNTSC · PAL · SECAM Image Size (Diagonal)24.6 in. - 246 in. Screen Distance3.9 ft. - 32.8 ft. Color Support24-bit (16.7M colors) Max Resolution (Interpolated)1600 x 1200 (UXGA) Synchronization Range Horizontal15 - 93 kHz Synchronization Range Vertical50 - 85 Hz HDTV Formats720p · 1080i · 480p · 480i
Technical Features
Audio OutputSpeaker(s) · 3.5 mm Mini Jack
Interfaces
InterfaceRS232C (mini DIN-8 pin) · USB Video Input4 Pin - Mini DIN (S-Video) · 15 Pin D-Sub VGA (& component) x 2 · Composite Video
Other Features
Special FeaturesKeystone Correction
Warranty
Warranty2 Years, 90 Days On Lamp
Dimensions
Toshiba Contact Information
Main support number800-457-7777
Sponsored Links
