20 Most Recent
Toshiba Tecra M4-S115TD Tablet PC Questions & Answers
Tegra M4 Intermittent green display
it very well could be ,but ram can also cause this problem try re seating memory if it still does it after re seating ram take one stick out then try if same resualts try the other if problem still exsist if you have additional ram avaiable try it with the ram that came with unit out if it still exsist im afraid it is not the ram but infact the card
Power/plug problem
first you need to see if the dc plug looks like this http://www.laptopjacks.com/view_part/Toshiba-Laptop-DC-Power-Jack-TS312030.html
if it does its just a simple unplug and replace .
Soundcard driver for Toshiba Tecra M4-PTM40A Tablet.
The XP SP2 driver should work.
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=980401&moid=893054&rpn=PTM42U&BV_SessionID=@@@@0801357951.1210987874@@@@&BV_EngineID=ccceadeedmeimgicgfkceghdgngdgmn.0&ct=DL&all_docs=false
Laptop won't startup!!
Problem with the BIOS. Please remove the BIOS batterya nd put it back.
This link will guide you in doing so:
http://www.computerhope.com/issues/ch000239.htm
On my toshiba tablet,I forgot my pass word.how do I reset it?
Not sure about specifics on toshiba tablets, but wanted to suggest that on other tablets you can hold the up volume(sometimes others its volume down) and power button at sane time for about 10+seconds and a menu will pop up for a rebooting, safe mode, and factory restart(which erases and reboots from scratch) worth a shot.. Yet, be careful what you select if it works.. Don't want you to erase stuff if you don't want to.... And btw most tablets have a little pin size hole either under the camera lense or on side that something like a paper clip can push a reset button... But don't think that helps with password.. Just if it freezes up and won't shut down... Good luck.. Sorry if this doesn't help...
