20 Most Recent
Toshiba Satellite A10 Notebook Questions & Answers
How do I remove the hard drive in Toshiba
The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
- Gently remove the cradle from the laptop, yes pull on it
- Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
- Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
- Re-install XP or Vista
4/14/2015 8:24:36 PM •
Toshiba...
Answered
on Apr 14, 2015
PLEASE I NEED DRIVENG WIERLESS
Giving the model # probably doesn't help in ID'ing the wireless card - assuming that's what you're asking for. Check it out physically: the WiFi mini-PCI card's compartment is in the bottom front, adjacent to the battery. Remove the compartment door (it's held by one screw), and see if there is a wireless card installed and what make and model it is. Then we'll figure it out...
7/5/2011 6:27:24 AM •
Toshiba...
Answered
on Jul 05, 2011
No sound in my toshiba
Check for device manager, may be the device drivers are not available.
check the drivers disk you got with you notebook or try taking backup from the notebook and install them.
the alternative way is to got for the toshiba download site
check the below link and select the exact model you got with you
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=download
then check the sound drivers and try installing them.
this should pretty much resolve your sound problem.
one more suggestion - Go for windows 7 which way far better than xp, vista
3/10/2011 10:04:30 PM •
Toshiba...
Answered
on Mar 10, 2011
Some keys not working
if the keys r not working its not software problem its hardware problem and it can only be set to right in shops
1/5/2011 10:11:04 AM •
Toshiba...
Answered
on Jan 05, 2011
Tosiba satellite a10 no power
probably the power supply unit is blown. Some machines nneed a battery to be working, even a little bit, to make them work.
Power supply units that fit all machines are cheaper than buying the brand one.
7/10/2010 7:27:09 AM •
Toshiba...
Answered
on Jul 10, 2010
Will not detect hard drive
Hi, from the Desktop, click to open your
Computer; check to see if there's a DVD RW Drive (D:) in the Device with
Removable Storage area. If the area is (Blank); Go to: Start, as in Log-off, click all Programs; scroll for a Media Disk Player. You made need to (Setup) your player. From either point you should be able to fix the problem. "If the solution helped?, "Ratings" is appreciated, thanks
2/23/2010 1:19:34 PM •
Toshiba...
Answered
on Feb 23, 2010
Error 0x000000ED
That error code implies a hard disk error, which is preventing your Windows from booting up,
Here is the Microsoft link on how to fix the problem.
http://support.microsoft.com/kb/297185
Happy New year.
12/31/2009 10:47:40 AM •
Toshiba...
Answered
on Dec 31, 2009
