20 Most Recent
Toshiba Satellite M45-S2652 Notebook Questions & Answers
Dear sir,
my toshiba m45-s2652 has
After insert the CD restart the PC and press F2 , F10 , F12 whatever is the case to change the boot order settings and select CD-ROM.Then start your installation from the CD-DRIVE.
If
you need more help come back.
Post
/ thumbs / testimonial are welcome!
12/17/2010 4:36:17 AM •
Toshiba...
Answered
on Dec 17, 2010
L350-170, Updated bios driver,note book shutdown,
Sounds like your BIOS update didn't Flash correctly. They usually give warnings at a website about the dangers\risks of updating your BIOS. Usually if the BIOS update didn't go well, then your computer, or the motherboard at least, is just a paper weight. Do you get any lights to light-up at all when pressing the power button. If so, then you have a chance of re-flashing your BIOS and maybe it will do it correctly the second time.
3/14/2010 5:13:39 AM •
Toshiba...
Answered
on Mar 14, 2010
L350-170 Logon Failure
Sounds like profile corruption or virus problem.
Try restarting the machine and tapping f8 until menu appears. Go into safe mode then logon as administrator. If you can get into windows, go to control panel then user accounts. Create new user account then restart machine. Log on using new user account and copy all personal files/folders to new user account.
6/7/2009 8:22:00 PM •
Toshiba...
Answered
on Jun 07, 2009
Toshiba Satellite laptop takes over 20 minutes to start up
Hi Marshall, and welcome to FixYa,
Have you tried everything?
Perform the steps given below to increase your system performance.
Uninstall all unwanted software:
To uninstall software
Click on Start à Settings à Control Panel à Add/Remove Programs
Select the software (one at the time) from the list and click on the Add/Remove button and follow the online screen instructions.
Erase unnecessary files in the windows temp folder.
Double Click My Computer.
Double Click the drive where windows are installed. This is typically drive C.
Double Click the windows folder. This is typically C:\Windows.
Double Click the temp folder. This is typically C:\Windows\temp.
Press control A to select all files and folders.
Press the delete key.
If confirmation is asked to delete these files choose yes to all.
Defragment hard disk.
Close all applications.
Disable your screen saver.
Disable all the programs on the taskbar if possible.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Select the drive to defrag.
You should defrag every hard disk on your system.
This process can take quite some time.
Click Ok.
Enable your screen saver.
Remove Startup programs (if you know what you are doing)
Click Start
Select Run
Type msconfig in the text box
The "System Configuration Utility" window will open
A list of programs will be shown each having a checkbox to the left of the name.
Click on the checkbox to enable the program (so it runs when windows boots) and click a second time to Uncheck the box to disable the program (so it does not run when windows boots).
Set the size of the virtual memory (swap file) to a constant optimal size.
Right click My Computer
Click Properties
The System Properties window lists the amount of RAM in your PC
Click Performance
Click Virtual Memory
Click Let me specify my own virtual memory settings
Click the arrow next to the hard disk.
Here are some guidelines to choose the best location for your virtual memory file
a) Select the quickest hard disk.
b) If you have, two hard disks that are similar in performance select the hard disk that does not contain Windows system files (usually C:).
c) Make sure the drive has free space equal to at least twice the size of the recommended swap file size.
d) If the partition is on the same physical drive, select the partition in alphabetical order. For example, if you have one 20GB hard disk and you partition it into two 10GB partitions drive C & D) You should pick Drive C over Drive D if meets all the guidelines of a, b & c.
Set the Minimum/Maximum to: With large hard disks settings at least 128mb or 256mb swap file should be sufficient in almost every situation.
Note: The amount of RAM plus the size of the virtual memory file is the maximum amount of RAM you can use at once.
Click OK.
After setting the size of the virtual memory file windows will display the following message. You have chosen not to let windows manage virtual memory automatically.
Click Yes.
You must restart your computer before the new settings will take effect. Do you want to restart your computer now?
Click Yes
Now, antivirus program? Have you got one?
http://free.avg.com/download-avg-anti-virus-free-edition
Next :-) please vote if this help you
2/8/2009 7:49:33 AM •
Toshiba...
Answered
on Feb 08, 2009
Cd/dvd drive wont open
You could try to manually eject the CD, may be the mechanism is stuck. Have a close look at the CD tray, there should be a tiny hole, then find a paper clip with a wire diameter that nicely fits this hole and poke it in there, this will release the CD tray and open it so you can retrieve the CD.
Hope this helps
1/12/2009 1:14:14 AM •
Toshiba...
Answered
on Jan 12, 2009
Harddrive removal/ installation
Flip the machine up side down, battery away from you, and you will see three covers. The center cover in the middle is the memory. The other two covers towards you, one on the left, the other in the center, the hard drive is under one of these two. I beleive it's under the one on the left, but it's been a while since I've had one of these machines in front of me.
8/13/2008 3:51:29 AM •
Toshiba...
Answered
on Aug 13, 2008
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM •
Toshiba...
Answered
on May 22, 2023
How can a fix error code oxcoooooof
Just restore your system from a backup taken before the error code started.
If you have no backup then you need to format your hard disk and do a complete reinstall of all your software.
3/19/2020 10:52:50 AM •
Toshiba...
Answered
on Mar 19, 2020
How to play a DVD on Toshiba Satellite Pro C850
If you know the DVD and the DVD drive is in proper working order, it could mean that the software you are running just may have some problems. Try downloading a copy of VLC (VideoLan Client) this application is free and open source (and no it's not something I created and am just trying to get people to use...it's just something that works great, and completely free) VLC can play almost any video file or DVD that it encounters. If VLC can't play it, I would think it's likely there may be something with your disk or your DVD drive.
3/11/2020 8:58:46 AM •
Toshiba...
Answered
on Mar 11, 2020
