Troubleshooting & Support
Hot Topics:
- overcharge
- Frost
- 1958xeb1
- frost dryer
- MBF
- compressor
- noise 13
- driping
- Repair Manual
- service manual
- overload clicks...
- program code
- fridge
- cold
- freezer
- noise minutes
- Refrigerator
- noise
- Stopped Cooling
- defrost
- reset
- mbf2256...
- refrigerator...
- fridge warm
- leak
- overload clicks
- freezer ...
- maytag mbf
- troubleshooting
- ice
- View All »
Problems & Solutions
ice maker. just installed water line. it was never
Wait a while for the ice maker to cycle 2 or 3 times. It ain't instantaneous.
The refrigerator is not working
Hello, Do you see frost built up on the back wall of the freezer? if you do it is very likely a deforsting failure that is causing the fresh...
I noticed that my side
Hi, Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can...
We have a Maytag refrig that is making an unusual
its most likely ice build up, if this is a bottom freezer type. It could still be ice on the fan even if its a top freezer or side freezer....
My freezer door handle is coming loose. How do I
The handle should slide to the left using the handle release card
MBR2256ES6 Maytag refrigerator with bottom
ice accumelating in the freezer , means the defrost system is not working, here is some easy tips to find out which component is...
refrigerator stop running lights are on but the
NOTE: This is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem But the solution is in...
ice is forming in the
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL ITWILL BE MUCH APPRECIATED. The cold control needs...
I keep developing a layer
If you are seeing an ice sheet at the bottom of the freezer, your drain is blocked. When the unit goes into defrost, the moisture will...
I have a Maytag refrigerator
Freezer working- top half not cooling
I have a similar thing going on and Gene answered me with this: Do you see frost built up on the back wall of the freezer? if you do it is...
freezer freezes over
Chirping sound for about 10 to 15 seconds each
hello, Is the chirping sound coming from freezer fan,the fan by the compressor,or is it from the compressor itself. If it is from one of the...
freezer is working . refrig slowly was loosing is
Hi, Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling Refrigeratornot...
mi refrigerator not work the compressor i change
See all Maytag MBF 2256 Bottom Freezer Refrigerator Solutions
Unsolved Problems
ice cream not freezing. everything else frozen in
ice cream not freezing. everything else frozen in freezer. compressor coils have already been cleaned,
Cant figure out how to
Cant figure out how to get the plastic divider on the top slide shelf of the freezer out! I dont want to crack the...
Relay switch replaced a couple of months ago.
Relay switch replaced a couple of months ago. Apparently, failed again. Why would a refrigerator 6.5 years old fail. Is...
freezer cold,fredgerator top warm, no
freezer cold,fredgerator top warm, no appararant air coming thru top opening got a bottom freezer . wife overstuffs...
See all Maytag MBF 2256 Bottom Freezer Refrigerator Problems
Manuals & Guides
TopDo you have a manual for Maytag MBF 2256 Bottom Freezer Refrigerator? - Upload it to FixYa!
Upload a manual for Maytag MBF 2256 Bottom Freezer Refrigerator
Specifications
TopKey Features
Full Product Name:Maytag MBF 2256 Bottom Freezer Refrigerator
Type:Bottom Freezer
Total Volume:22.1 cu. ft. / 626 liter
Ice Maker:With Ice Maker
Total Number of Shelves:4
Fresh Food Compartment
Door Opens:Opens to Left and Right
Dimensions
Overall Depth:33.25 in.
Overall Height:69.88 in.
Overall Width:35.63 in.
Warranty
Warranty:2 Years Parts
Warranty:1 Year Parts and Labor
Warranty:5 Years Parts and Labor (Sealed System)
What's your problem?
Fix-O-Meter
2,971
2,971 people have viewed this product
- 45 people asked about this product.
- 22 people found solutions for this product.
- 8 people have added this product.
Pins on the...
How to fix your...
Ice Maker...
