Toshiba 62HM195 62 in. HDTV Television
Problems with Toshiba 62HM195 62 in. HDTV Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Troubleshooting and Support
Solved Problems for Toshiba 62HM195 62 in. HDTV Television RSS Feed
View More Results for Toshiba 62HM195 62 in. HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Toshiba 62HM195 62 in. HDTV Television RSS Feed
Answer
have picture but no sound and when i turn the tv on the lamp light blinks for awhile and then the tv... (More)
Answer
The picture has a double exposure look with red color bands across the screen, especially when a lot... (More)
Answer
After almost 2 years of trouble free operation, the bottom half of my screen has become all... (More)
Answer
When the TV is turned on the picture is fine. However, after a minute or so the picture starts to... (More)
Answer
Toshiba 62" HM 195 Half the screen is clear and half is fuzzy green kind of Luminating.
Answer
we had no picture, and replaced the bulb,, t.v. worked great then started to go green as in tint..... (More)
Answer
im having trouble locating the ic for the vertical output. im having lines from the middle of the... (More)
Find a Manual
Toshiba 62HM195 62 in. HDTV Television Manuals & Guides
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Toshiba 62HM195 62 in. HDTV Television
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Toshiba 62HM195 62 in. HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Toshiba 62HM195 62 in. HDTV Television
Key Features
Screen Size
62 inch
Digital TV Standard
HDTV - HDTV receiver is integrated. · HDTV
Projector Technology
DLP
Display Resolution
1920 x 1080 pixels
Display Capabilities
Aspect Ratio
16:9
Built-in Tuner
NTSC · ATSC
Digital TV Standard
Broadcast Format Supported
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Broadcast Format Displayed
Remote Control
Remote Control
Universal
Illuminated Remote
Illuminated
Image Quality
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Surround Sound Type
Dolby Digital / AC3
Technical Features
Picture in Picture
With PIP
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Energy Star Compliant
Non-Energy Star Compliant
Connectors
Headphone Jack
Without Headphone Jack
Rear Input Connectors
Component x 2 · S-Video x 2 · Composite x 2 · RF x 2
Front Input Connectors
Composite x 1 · HDMI x 1 · Firewire (IEEE 1394) x 1
Rear Output Connectors
Composite x 1 · Audio (RCA) x 1 · Optical Digital
Memory Card Slot
CompactFlash Card · SD Card · SmartMedia Card · MMC Card · Memory Stick
Screen Text
OSD Languages
English · French · Spanish
Channel Labels
With Channel Labels
Closed Caption on Mute
With Closed Caption On Mute
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 20 Watt
Dimensions
Depth
18.78 in.
Height
39.25 in.
Width
57.08 in.
Weight
105 lb.
Toshiba Contact Information
Main support number800-457-7777
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
