Caution The fan used to cool the Cable Card has stopped. Please unplug the TV power cord from the...
(More)
Caution The fan used to cool the Cable Card has stopped. Please unplug the TV power cord from the wall and contact
I have a Toshiba DLP 42HM66.  It began flashing white - like lightning strikes....
(More)
I have a Toshiba DLP 42HM66. It began flashing white - like lightning strikes. I've heard the horror stories related to the lamp and color wheel and light engine etc. I grabbed my handy screw driver and headed in. For my TV, it just needed a good cleaning. I vacuumed out all the dust bunnies and used condensed air to clear the dust building on the edge of the color wheel. No more flashing. BUT... I've put something back in wrong and now the picture hits the viewing screen about 3 inches lower than it should. This means that the bottom 3 inches is completely cut off.
Any body know what I've done?
Thanks
Gee, what do youthink the problem is. Of course = the light enging went. I already replaced the...
(More)
Gee, what do youthink the problem is. Of course = the light enging went. I already replaced the bulb. junk...
I have a toshiba 62HM15A. I had the light engine replaced 2 yrs ago. Now the picture flickers and...
(More)
I have a toshiba 62HM15A. I had the light engine replaced 2 yrs ago. Now the picture flickers and some colors look faded especially reds.
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
written by Ecollier2012
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
