Toshiba 26HF85 26 in. Television
Problems with Toshiba 26HF85 26 in. Television?
Troubleshooting and Support
Solved Problems for Toshiba 26HF85 26 in. Television RSS Feed Post a New Problem
LG Plasma TV 42''
purchased two years back from MIRC ELECTRONICS LTD.MUMBAI,INDIA LG make Plasma TV 42'' Model No.EPT 4200BP The...
1 Solution
poor picture with hdtv Hitachi 37HDL52...
the tv works fine on video inputs(yellow) , but not properly using the component inputs from the cable box or the dvd...
1 Solution
akai lct2785ta Sound Problem
Every time I change the channel, the sound defaults to Mono and I have to press the MTS button to change it to Stereo. I...
1 Solution
My JVC PIP Won't work, pls help!
Hi, I just bought a JVC Flat Screen AV-21ST27. I hooked up all the cables properly: Cable Tv, DVD, VCR are all working...
Post a Solution
plasma screen
i have two black stripes from top to bottom of my plasma screen how do i remove them
1 Solution
Parts
I own a digimate DG4200 42 in. Plasma , had a power surge picture went bad Can't find replacement part422BLOWR...
1 Solution
42" philips plasma flat panel...
I have a blue color bleeding in from the left side of the screen. It appears that when there is a white color that...
Post a Solution
Unsolved Support Problems
Unsolved Problems for Toshiba 26HF85 26 in. Television RSS Feed Post a New Problem
When we turn the TV on, the screen is just...
Sometimes when we turn the TV on, the screen is blue with horizontal white lines. After a few minutes, the picture will...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Screen Size26 inch
Display Capabilities
Built-in TunerNTSC
Broadcast Format Supported1080i (HDTV) · 540p
Image Quality
Adjustable Color TemperatureWith Adjustable Color Temperature
Remote Control
Remote ControlUniversal
Illuminated RemoteIlluminated
Audio Features
Audio OutputFixed
Audio TypeVirtual Surround
MTS StereoSAP / MTS Stereo
Technical Features
Picture in PictureWithout PIP
Parental ControlV-Chip
Sleep TimerWith Sleep Timer
Energy Star CompliantEnergy Star Compliant
Connectors
Rear Input ConnectorsS-Video x 2 · Audio (RCA) x 2 · Composite x 2
Front Input ConnectorsComposite x 1 · Audio (RCA) x 1 · S-Video x 1
Screen Text
OSD LanguagesEnglish · French · Spanish
Channel LabelsWith Channel Labels
Closed Caption on MuteWithout Closed Caption On Mute
Speakers
Number of Speakers2 Speakers
Speaker Power2 x 5 Watt
Dimensions
Depth19.5 in.
Height19.75 in.
Width27.5 in.
Weight79.2 lb.
Warranty
Overall Warranty1 Year
Toshiba Contact Information
Main support number800-457-7777
Sponsored Links
Loading problems.
Top Experts
Ask Me
Jaime867 Guru
27 solutions
Ask Me
sparkspyr Guru
10 solutions
Ask Me
ima_rm200 Wiz
6 solutions
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
