Toshiba SD4980 DVD Player
Problems with Toshiba SD4980 DVD Player?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Top
Experts
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Toshiba SD4980 DVD Player RSS Feed
Click here to get instant support from our best Experts!
View More Results for Toshiba SD4980 DVD Player
Questions and Unsolved Support Problems
Unsolved Problems for Toshiba SD4980 DVD Player RSS Feed
Answer
I need an optical jack outlet for my toshiba sd4980 dvd palyer
Answer
I have a Norcent DP 215 DVD player that has worked well for a few years. The other day, I... (More)
Answer
I assume that's short for "bad disc", but it happens for every DVD I try to play. Any...
Answer
We had dvd hooked up to plasma tv with rbg cables and it was working fine. After adding home theater... (More)
Find a Manual
Toshiba SD4980 DVD Player Manuals & Guides
Tips & Tricks
(Post a New Tip)
My player does not read disks
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will... written by ginko
Factory Reset
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down... written by xmarine2847
Help FixYa, Help you and help others. Share your User maunals and service...
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the... written by stoneheaded
Having trouble recording TV broadcast to DVD?
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then... written by MateusDIY
Owners Manuals
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems... written by stoneheaded
Dish Network DVD Remote Codes
DVD Codes BRAND COMBO CODE Aiwa DVD 634, 694, 751 Alpine DVD 653 ... written by stoneheaded
if the disc tray doesnt open then follow these tips
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you can open the disc tray now 4)if there are any dust particles or... written by dileep007
Cleaning your cds or dvd discs
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if... written by BobbyR1234
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for SD4980 DVD Player
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Find an Expert
Meet our 4705 DVD Player Experts
budmrtn
#1: budmrtn
Rank: GuruGuru
Televisions & Videos ExpertExpert
Rating:  88%, 162 votes
Solutions:  773 (753 Votes in the last 30 days)
Experience: 30 Years of professional repair and design.
projdoc
#2: projdoc
Rank: GuruGuru
Rating:  94%, 611 votes
Solutions:  1205 (473 Votes in the last 30 days)
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Chu3505
#3: Chu3505
Rank: GuruGuru
Rating:  85%, 419 votes
Solutions:  1360 (377 Votes in the last 30 days)
Experience: I was an engineer for 20 years.I repair tv all models for 15 years for friend shop,was my hobbies.
cene765
#4: cene765
Rank: GuruGuru
Rating:  89%, 407 votes
Solutions:  769 (366 Votes in the last 30 days)
Experience: More than 5 years attempt with printers, computers and all office equipment
dmftrucker
Rank: GuruGuru
Rating:  87%, 413 votes
Solutions:  1581 (361 Votes in the last 30 days)
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
justaskjoe
Rank: GuruGuru
Rating:  85%, 2026 votes
Solutions:  3902 (348 Votes in the last 30 days)
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
k24674
#7: k24674
Rank: GuruGuru
Rating:  87%, 677 votes
Solutions:  1631 (330 Votes in the last 30 days)
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Nomodo4u
#8: Nomodo4u
Rank: GuruGuru
Rating:  89%, 270 votes
Solutions:  480 (320 Votes in the last 30 days)
Experience: By using this stuff I know what I know when I know, but sometimes don't know how I know you know??
localwonder
Rank: GuruGuru
Rating:  92%, 2808 votes
Solutions:  4963 (307 Votes in the last 30 days)
Experience: I have yrs of experience dealing with many situations.
komguy
#10: komguy
Rank: GuruGuru
Rating:  90%, 1239 votes
Solutions:  1560 (290 Votes in the last 30 days)
Experience: I have been a Canon certified warranty repairman for 4 years. Always on top 10 national list.
Find a Warranty
Specifications for Toshiba SD4980 DVD Player
Key Features
DVD Type
DVD Player
Number of Discs
Progressive Scan
With Progressive Scan
Playable Disk Types
CD-RW · CD-R · CD (Audio) · VCD · DVD-RW · DVD Video · DVD-R
Playable File Formats
JPEG · WMA · MP3 · DivX · MPEG4
Video
Picture Control
Zoom
Video Output System
NTSC
Video DAC
10 bit / 54 MHz
Audio
Surround Sound
DTS (Digital out only) · Dolby Digital (Digital out only) · Virtual Surround
Audio DAC
24 bit / 192 kHz
Dynamic Range
93 dB (DVD)
Audio S/N Ratio
100 dB
Connections
Outputs
Composite x 1, S-Video x 1, Component x 1, HDMI x 1, Analog Audio x 1, Digital Audio Coaxial x 1, Digital Audio Optical x 1
Convenience
Remote Control
Yes
OSD
Yes: English, French, Spanish
Parental Control
Yes
Display Dimmer
Yes
Dimensions
Depth
7.87 in.
Height
1.65 in.
Width
16.93 in.
Weight
3.53 lb.
Warranty
Warranty
90 Days
Toshiba Contact Information
Main support number800-457-7777
Describe your problem:
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
