20 Most Recent
Xerox XA7-17i 17" LCD Monitor Questions & Answers
I bought 42 xa7 xerox
sell me one of the internal screen connecting to comp cables dvi-d if poss. and i will give you a thousand blessings. MAC. LOL
Screen goes black lights goes
Try another monitor. If another monitor does the same thing. Then your issues would be a possible seeting. Copy and paste this >
Control Panel\Power Options < in to a folder location pane.
In to: Yellow highlited area and hit enter. This will take you right to the Power settings page.
"If this helps you - Please give positive coments"
Thank you for your Visit!
Stays on for 5 minutes then cuts out every 15
hdemou, Possible that unit has bad solder joint on SMPS power supply board or near the CCFL "inverter" supply circuit components. Someone will need to do a very close-up inspection of the soldering to detect the thermal intermittant. It will most likely be "ON" or "NEAR" a component that has been temperature cycled (cold to hot, cold to hot) many times during units life history! Also verify that SMPS/inverter board(s) have good electrolytic filter capacitors! Not swollen or leaky! ref.
www.ccl-la.com/badcaps.htm and
www.badcaps.net Good luck! Hope info provided is of some use. 12fixlouie
My monitor gets no input signal, computer does
Try the montor on the external vga connection of the laptop. You can swap the signal from the laptop screen to the external monitor using the swap key (usually a FN key). You can do this whilst the laptop is up and running. If you see the display there, then you know the monitor is o.k. Then check the connection to the PC. If it is a card (PCI/AGP) make sure the card is properly seated. If you don't see display on either check the pins on the monitor plug if any are bent or missing. Sometimes these pins can be accidentaly pushed back into the plug housing. You can retrieve them with small long-nosed pliers.
HOW TO RESET FORGOTTEN PASSWORN ON A XEROX 7435
If the default username and password (admin/1111) are not working on your Xerox 7435 printer, you can try resetting the password to its default settings using the following steps:
Turn on the printer and wait for it to boot up completely.
Press the button with a wrench icon on the printer's control panel to enter the settings menu.
Use the arrow keys to navigate to the "Security" option and press the OK button.
Select the "User Authentication" option and press OK.
Enter the current password, if you remember it. If you don't remember it, leave it blank.
Select the "Reset User Accounts" option and press OK.
Select the "Restore Defaults" option and press OK.
Confirm that you want to restore the default settings by selecting "Yes" and pressing OK.
After you have completed these steps, the printer's password will be reset to the default settings (admin/1111). You should now be able to log in to the printer's settings menu using these credentials.
Xerox Workcentre 7535 LED's flashing repeatedly when powering up
Hai this is Arun. If your motherboard gets power but the computer not starting then there are two solutions :
- Unplug the wire that is coming from the power switch to the motherboard & plug it again.
- If it is still not starting, then remove your CMOS battery and insert it again in the motherboard.
Hope these steps may solve your problem.
Thanks.
XEROX PRINTER CUSTOMER SERVICE {18OO*scammer69} pHoNe NuMbEr ==
FixYa Experts: Once you have reached a certain number of answers, then you can Edit and Delete these spam posts too, so they don't victimize unwary users. By my estimate, 4 of your fellow volunteer Experts are currently deleting 2500 spams per day, and it's not keeping up with the flood. Please help us out.
