20 Most Recent Rosen NECVOX RE1569D Car DVD Player Questions & Answers
My husban had to unscrew the whole DVD player and found that one red wire was loose, he did weld it and it worked again.
Rosen NECVOX... | Answered on Apr 08, 2012
the entire screen needs to be replaced but u can try passing a magnet over the screen in a figure 8 pattern
Rosen NECVOX... | Answered on Apr 19, 2009
Hi Gill.
Check, Make sure the cables are connected. Try cleaning the laser and the DVD. Make sure the TV is on the correct input.
try swapping one of the sound cables to see if the yellow cables is in fact damaged.
1) Plug the DVD player in to the TV that it does work on. Make sure there is no disc in the player. Check the DVD players set up menu. Look in the Picture menu and change the output to "RGB" Move the player back to the TV/VHS Combi. Select the input that gives you RGB1.
2) Same as above, but this time change the Picture menu to PAL (or composite or Video....whatever is the other option name that isn't RGB or S-Video). Retest on the Combi, but this time you want AV1.
If these don't work then you might need to have a look in the TV manual about connecting external sources. It could be that because the combi has a recorder that it's trying to stop you from copying DVD to VHS. See if there's an input on the combi that bypases the recorder.
Read more: https://www.diynot.com/diy/threads/dvd-problem-sound-but-no-picture.211588/#ixzz5FYrJiX6o
I found all this on the internet so not sure if it will help you out.
or try this link.
dvd player has sound but no picture Google Search
Rosen Car Audio... | Answered on May 15, 2018
Please post once
Rosen Car Audio... | Answered on May 03, 2018
It is cheaper to replace it than try and find someone who can fix it.
Sounds like either that dvd player is on a different channel. Look for a channel switch on the headphones and also check the on screen menu to see what channel it is set to.
Rosen Car Audio... | Answered on Aug 14, 2016
that's probably the parental security code. Contact manufacturer or dealer for possible override code
Rosen Car Audio... | Answered on Jun 28, 2014
Rosen NECVOX RE1569D Car DVD Player Logo
5 questions posted
Top Rosen Car Audio & Video Experts
Pierre Laplante
rd2xpld
Are you a Rosen Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Rosen Car Audio & Video
Most Popular Question
necvox re 1569 screen
  • Car Audio & Video
