20 Most Recent Maytag CWE5800A Electric Double Oven Questions & Answers
2answers
Maytag oven beeping the message is F5 oven needs to be turned off
Hello, the oven can be turned off from the breaker panel, the Error message F5 refers to your electronic oven control is bad. You can try to reset it by turning the breaker off for 20 minutes and reseting the breaker..if this fails to work you will need to replace the EOC. Hope this helps, if you have any further questions please feel free to comment again..Good Luck!!!
11/24/2022 3:38:21 PM • Maytag CWE5800A... • Answered on Nov 24, 2022
Oven won't turn off!
it probably needed to reset computer/electroics but i would call customer service for the brand it is a dangerous thing to play with. make sure there were no recalls also.
4/5/2017 1:05:51 PM • Maytag CWE5800A... • Answered on Apr 05, 2017
Power outage last night. Was going to reset the clock. Pushed clock, and now it says SA6 and is frozen.
Switch off at the wall switch then on again , this should reset the controls.
6/5/2016 5:00:52 AM • Maytag CWE5800A... • Answered on Jun 05, 2016
0answers
2answers
Oven won't heat up, but no error codes
I called the repairman for help. Turns out that one of the suggestions would have worked if I could go to basement turn off breaker then run up and carry out the suggestion and run to the basement again and turn back on breaker, then up again faster. The repairman was able to fix problem by using me as the go between the breaker and the oven. He stayed up and I stayed down thereby eliminating the problem of not being able to run up and down fast enough myself. The two of us were able to make things happen in the time limit. I think I should have gotten a break on the bill since I played helper!! If anyone else has this problem and has closer access to the breakers than I, they would be able to cut the repairman out of the picture and save the service fee. Maybe I should run up and down from oven to breakers for a set amount of time for exercise in preparation for the next oven problem. May be easier to get a new oven without a computer in it if such a thing exist anymore because at 77+ I don't think I am going to get much faster even with exercise.
4/16/2014 3:30:13 PM • Maytag CWE5800A... • Answered on Apr 16, 2014
Hi
Thanks for using FixYa. Error F2/F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
3/14/2013 10:59:57 AM • Maytag CWE5800A... • Answered on Mar 14, 2013
Door won't open after self cleaning and cool down has stopped.
if you are sure it has cooled down cycle it again to clean hitting the cancel button shorty after it starts
12/9/2011 9:04:30 PM • Maytag CWE5800A... • Answered on Dec 09, 2011
Lower heating element will not work and I have
Hello, harrah I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this Informational site may not have your exact model or brand, this site will help you a lot. Here is a site link about everything you want to know about ovens and possibly yours, from repair to trouble shooting it. Now go easy on me, I am just trying to help. If it does great if not, I am sorry.
http://home.howstuffworks.com/how-to-repair-an-oven.htm Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help. Thanks, Mike http://beta.fixya.com/users/mc1bean
10/28/2011 9:12:38 PM • Maytag CWE5800A... • Answered on Oct 28, 2011
Instructions to set cooking time on and off
Hello, pb I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this Informational site may not have your exact model or brand, this site will help you a lot. Here is a site link about everything you want to know about ovens and possibly yours, from repair to trouble shooting it. Now go easy on me, I am just trying to help. If it does great if not, I am sorry.
10/28/2011 9:03:01 PM • Maytag CWE5800A... • Answered on Oct 28, 2011
Just installed a Maytag double
Hello, prosteet I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this Informational site may not have your exact model or brand, this site will help you a lot. Here is a site link about everything you want to know about ovens and possibly yours, from repair to trouble shooting it. Now go easy on me, I am just trying to help. If it does great if not, I am sorry.
10/28/2011 8:48:17 PM • Maytag CWE5800A... • Answered on Oct 28, 2011
Displays F-7 fault code and beeps.
Hello, ronv I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this Informational site may not have your exact model or brand, this site will help you a lot. Here is a site link about everything you want to know about ovens and possibly yours, from repair to trouble shooting it. Now go easy on me, I am just trying to help. If it does great if not, I am sorry.
10/28/2011 8:39:00 PM • Maytag CWE5800A... • Answered on Oct 28, 2011
Maytag CWE5800A Electric Double Oven Logo
68 questions posted
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
View Most Popular
Maytag Ovens
  • Maytag Ovens
Most Popular Question
oven won 39 t heat up but no error
  • Ovens
