20 Most Recent
Coby 5.1 Channel Home Theater Speaker System System Questions & Answers
My ampex 5.1 hoofer systems
I think its capacitors are worn out,my system had a similar problem,its capacitors were swollen on opening it up from the back,i bought new ones and they were soldered in place of the worn out ones and it stopped roaring
My ampex 5.1 channel home theater speaker system
Possible there are DRY SOLDER JOINTS within the main board and so when the set heats up there is a connection loss which makes the set switch off. Remove panel and try to work the set while cooling with a fan , touch to see if any section like power-amps gets hot. If so observe with a magnifier and solder.
Check the external antennae connection to the system, if this seems ok then the RF end/ signal processor is faulty which might need a trace with technical help.
