20 Most Recent
Coby MP-C941 MP3 Player Questions & Answers
How do i re format my coby mp3 player with out the
Generally you cannot reformat something without clearing it. It is possible to remove everything on the device and then reformat and reload everything which could quite possibly solve your error problem.
Freezing
dmerunka,
hi, just want to ask if, before you've dowloaded song to your mp3 have you scan it for possible virus? it's adviceable to scan 1st all dowloaded song before transferring to mp3 player for some of it have imbeded malware and virus. most common virus is the brontok which will freeze your played files then shut it off.
try to download " ESET nod32" anti virus and scan your mp3 for possible virus infection. NOD32 have a free trial and can still work even if the trial period expired.
cheers,
mark
Problem
you should hook up the player and format it on your pc
HDD read error
I had the same problem with my mp3 player. The problem seems to be that the charge had been depleted - even though the screen said the charging was complete when I plugged it in. Disregard the screen, charge your machine for two hours, and if your player is like mine, it will be functioning properly afterwards. Hope that helps.
Creating Playlists
You need to do the following steps:
1. While the song is playing, press and hold the joystick button. A screen will pop up.
2. Select 'Favorite (+)'. Once you do this, you should be able to see the song in your 'Favorites' folder.
MP3 is stuck on radio mode
Ok, I think I might know how to solve this. You might need to fix your firmware. Try going onto this website: http://cobyusa.com/_en/support_md.php
Once you get there, go through the list of dvd, cd, and TV model numbers until you find your's (Should be on the back of your player) then download the firmware. Then place it into the player and unplug the player from your computer and start it up. It will take a minute or two for your player to start up, due to it installing the firmware, but you shouldn't have a problem from there.
I hope this works and have a nice day.
Loading issue
Have never worked on this model but on any other make you would be at main board replacement stage I'm afraid,.Sounds like microprocesser ,eprom fault.Sorry but not cheap fix by the sounds of things,how old is unit,any chance is under guarantee.You could try bringing it back to where you bought it,.
