I've a DF4150P dvd/vcr player. It worked fine until last night when I tried to open the disc tray...
(More)
I've a DF4150P dvd/vcr player. It worked fine until last night when I tried to open the disc tray to put a dvd in and it wouldn't open. The display says "open" but nothing happens except two short buzzes from the machine, then it says "no disc" and then, I think, "PROS" or "PRO5". I tried both the remote and the manual button - repeatedly. I looked for a small hole to release the tray with a piece of wire - there doesn't seem to be one - and no guidance in the user manual - which I still have! Any constructive suggestions, please?
dish network satelite rcvr hooked up to dvd vcr combo with unit off can watch sat with unit on play...
(More)
dish network satelite rcvr hooked up to dvd vcr combo with unit off can watch sat with unit on play tapes want to record when turn on just get blue screen
i have put some footage from my HD camcorder onto my lap top and then onto disc but it will not play...
(More)
i have put some footage from my HD camcorder onto my lap top and then onto disc but it will not play on my panasonic dvd player/recorder and just shows UNSUPPORT on the display.
DVD player makes sounds over and over and won't play previous played dvds - if no sol'n please tell...
(More)
DVD player makes sounds over and over and won't play previous played dvds - if no sol'n please tell me who can fix in san jose cal area. thank you
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
