20 Most Recent
Leica R4 35mm SLR Camera Questions & Answers
Film rapid shutter wind won't
The r series are notorious for inferior parts,first have a CLA done by a professional,and if a (clean,lubricate,adjustment) doesnt solve the problem then actual repairs will be necessary for repair by a qualified Leica Service Center
R4 problems
If what you are saying is that the camera will only fire on B and 1/100 with a good battery there is a problem with the shutter. Clean battery contacts in the battery compartment and polish both ends of the battery to improve current flow, and try another battery, if you still get a problem you may need service,
12/22/2013 12:46:21 AM •
Leica...
Answered
on Dec 22, 2013
My camera is stuck
Why do you think your camera does not work?
What have you seen (or not seen while expecting)? Did you recharge the battery? Is everything with your camera the same as it was the last time you used it?
12/5/2013 5:08:18 PM •
Leica...
Answered
on Dec 05, 2013
USED BUT CLEAN WHITE CHROME
Sorry, FixYa is an online information resource only and does not supply spare parts or any other tangible goods or services.
2/21/2011 2:22:40 PM •
Leica...
Answered
on Feb 21, 2011
Just received a Leica D.R.P. Ernst Leitz Wetzlar
Hey there! Gonna give you nice end of year gift! Go to Ebay, look up Willard D Morgan. There is a seller who can supply one of the best Leica manuals out there. There are 10 days left on the item with a Buy-it-now price of $11.98! The name of the seller is ljs18. Check it out--you shouldn't be disappointed.---Hope I helped you!---Rick
12/30/2009 1:40:29 AM •
Leica...
Answered
on Dec 30, 2009
Film won't load on Vectis 300 MinoIta
The clue is in your descrition; Old.
If the mechanism has jammed, due to age or lack of use that causes tarnisg=hing on the contacts, the motor/mechanism will not load.
I would get it serviced at an aurgorised Minolta repair shop.
Contact Minolta for a list of authorised repairers.
3/22/2024 7:04:40 AM •
Photography
Answered
on Mar 22, 2024
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
If your picture frame is not recognizing the 16GB PNY card and displaying a "No Card" message, there could be several reasons for this issue:
- Compatibility: Some picture frames may have limitations on the size or type of memory card they can accept. Ensure that the picture frame is compatible with SDHC or SDXC cards, as these are the types commonly used for higher-capacity cards like 16GB.
- File System: Check if the memory card is formatted in a compatible file system such as FAT32 or exFAT. Some picture frames may not recognize cards formatted in other file systems. You may need to format the card using a compatible file system on your computer before using it in the picture frame.
- Card Reader Slot: Ensure that the memory card is inserted correctly into the card reader slot of the picture frame. Sometimes, improper insertion can prevent the device from detecting the card.
- Card Compatibility: While SDHC and SDXC cards are generally backward-compatible with devices that support SD cards, some older picture frames may have limited compatibility with higher-capacity SD cards. Try using a lower-capacity SD card (e.g., 2GB or 4GB) to see if the picture frame recognizes it.
- Faulty Card or Picture Frame: If none of the above solutions work, there may be an issue with either the memory card or the picture frame itself. Try using the memory card in a different device to check if it's functioning correctly. Similarly, try using a different memory card in the picture frame to see if it's able to recognize it. If the problem persists, there may be a hardware issue with either the card or the picture frame, and you may need to contact the manufacturer for assistance or consider replacing the faulty component.
By following these troubleshooting steps, you should be able to determine the cause of the issue and resolve it accordingly.
3/16/2024 9:30:07 AM •
Photography
Answered
on Mar 16, 2024
Need OptiPix Pro software
I own the OptiPix DPF and here is a pic of the owners manual with directions for the OptPixsetup file.
11/25/2023 1:11:02 AM •
Photography
Answered
on Nov 25, 2023
