20 Most Recent Hitachi 42PD7800 42 in. HD-Ready Plasma Television Questions & Answers
reset tv unplug one minute turn off main power plug in turn on main power try again, if not try different input and source ie dvd player or cable box
Hitachi 42PD7800... | Answered on Apr 26, 2019
You have main board issues, there is a 3.2 volt regulator on your TV that gives issues and will make the set turn on at random times, replace the main board and it should fix it, or you can order the part for under a buck from China and replace it yourself if you have soldering skills
Hitachi 42PD7800... | Answered on Jan 31, 2018
i have the same problem did you ever get this fixed??
Hitachi 42PD7800... | Answered on Apr 21, 2010
First off I did not see make or model. When plasmas die you have failure in either the power supply of the sustain boards. Do you have any voltage readings from va or vs ?
Craig www.classtorations.com
Hitachi 42PD7800... | Answered on Apr 27, 2009
If it goes all the way from top to bottom, you have a bad panel. much to expensive to repair
Hitachi 42PD7800... | Answered on Jan 15, 2009
Talked to Hitach and yes a dicky tuner. but it's ok they will replace the tuner card but it will take 4 weeks to get one. :o(
So I have my nice new TV but I can not use it for 4 weeks
Not happy.
Hitachi 42PD7800... | Answered on Mar 19, 2008
Use your remote to reconfigure the picture. There may be a picture button on the remote that will switch the picture from 4:3, 16:9, Standard, Stretch, and so forth.
Hitachi 42PD7800... | Answered on Feb 24, 2008
switch on the dvd player so it's playing, then do a new master tune. press the dtt/tv button so you are watching the internal freeview system, then press menu, then go to installation, and re-install all channels. the tv will then detect your dvd player in the intial set up/tune mode.
hope this helps..
Hitachi 42PD7800... | Answered on Nov 24, 2007
According to what i could find, there is no way to actually SOLVE the problem, this is what i did find; The plasma display panel is lighting the phosphors by the discharge of internal radiation. Depending on the screen contents, in rare cases this may cause vertical stripes to appear because of failure to light. Please note that this is not a malfunction.
Hitachi 42PD7800... | Answered on Aug 13, 2007
Just cut the 2 wires to the switch and cut he insulation back and twist them together with a wire nut......use a switchable power bar to turn it on and off......I did this to a Realistic amplifier and it works fine...........
Hitachi... | Answered on Jun 04, 2019
i don;t know. please put it back, hooked up the same way to see if the tv is the problem. if tv is ok, it seems the cable or
connectors may be loose or connected wrong. if single cable, dollar stores sometimes have new long tv cables you could run from original supply to new position to help you locate problem wire or connector.
Hitachi... | Answered on Jun 03, 2019
Hello Michael, I sent you the link of the user manual
I hope you can solve the problem
Greetings Franco Dosil
Hola Michael, te envio el link del manual de usuario
Espero puedas solucionar el problema
Saludos Franco Dosil
https://data2.manualslib.com/pdf2/47/4667/466619-hitachi/22ld5550u_users_manual.pdf?57aa459728c869ba6c471ef6617d380f&take=binary
Hitachi... | Answered on May 19, 2019
Your Hitachi remote controls are not functionally interchangeable. Win some, lose some.
Hitachi... | Answered on May 18, 2019
Hello Grant, I am sending you the link to download the user manual of your Hitachi TV and check out the procedure of what you need
I hope that my suggestion serves you and you can resolve your concern
Hola Grant, te estoy enviando el link para que descargues el manual de usuario de tu TV Hitachi y consultes ah? el procedimiento de lo que necesitas
Espero que te sirva mi sugerencia y puedas resolver tu inquietud
https://www.libble.eu/hitachi-l46vf04u/online-manual-649167
Hitachi... | Answered on May 17, 2019
Turn it off and then on again.
Please let it close for some time and then again turn it on.
Hitachi... | Answered on May 12, 2019
Hitachi 42PD7800 42 in. HD-Ready Plasma Television Logo
20 questions posted
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
no power
  • Televison & Video
