20 Most Recent Hitachi 32HDL52 32 in. LCD Television Questions & Answers
Sounds like the main board problem. You can get parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Hitachi 32HDL52... | Answered on Jun 27, 2017
Hi Albert,
PS3 is a beautiful gadget. Please give some time to the user manual. One has to be a little friendly with PS3 before using and enjoying it.
Hitachi 32HDL52... | Answered on Aug 06, 2015
Consult the owner manual (you can GOOGLE to find one with the model number if you do not have it) to see if the set has a feature to lock out channel being changed---this feature is on some sets so if using a box children etc cannot change the channel.
You can also try to route your signal to a rear audio/video input and change input to that input and change channels with the box if you use one.
Hitachi 32HDL52... | Answered on Mar 31, 2012
It's the problem of overheating in the power supply board of the TV.on the power supply board of the tv there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hoping this helpout in solving the problem...
Hitachi 32HDL52... | Answered on Jul 04, 2011
Read the manual about picture in picture and turn it off. I hope this helps.
Hitachi 32HDL52... | Answered on Apr 04, 2009
Try allied electronics and newark, both excellent service, may have to cross referance the part number though. I hope this helps.!
Hitachi 32HDL52... | Answered on Jan 13, 2009
TV is a lot like life. There is some personal taste and some trial and error. There is no such thing as "perfect" with a TV picture. What I like, you might not. And test-pattern "perfect" is not right for everyone.
Many years ago when I was doing TV service, I repaired a set with no picture and then found that once I got the picture back, it was distorted and everyone was shown with a big head and tiny body. I adjusted the picture to make the on-screen people look "normal." I later got a call from the irate customer, who did not like "normal-size" heads. They had been watching the set so long with big heads that they had become accustomed to seeing it that way and thought it was wrong when it was not distorted. I could have explained it to them and they might have accepted it that way but they were much happier when I went back and adjusted it the way they wanted it -- with big heads and all. So that is what i did.
Now back to your problem: Don't be afraid of using the set. Go ahead and plug it in, connect it and turn it on. many people will be happy with it right out of the box.
Others will need just a few tweaks.
So don't be afraid to adjust the tint to get a nice shade of skin tones. There is also automatic flesh tone that can be turned on or off, so you don't need to adjust it for each channel or face.
If you are a perfectionist, as I am, you will also want to adjust the brightness, contrast, saturation and sharpness -- for your own taste. By making slight changes over a few days or weeks you will find the "perfect" set up for YOU -- but don't expect to do this right away or even the first day. You'll come close, but it gets better as you fine tune it.
You'll probably want to try the different filters and advanced settings. However, I would stay away from the Y B G. It is there in case the set arrives improperly setup and one color is too strong a technician will use those to fix the problem. Also as the set gets older and one of the colors weakens, it will enable boosting one (or more) of the colors.
You can also buy set a up DVD that will help you adjust the set to a factory standard. But, I prefer to do it myself and get it to MY liking.
As for your parents. adjust it to there taste and they probably wont need the fine-tuning that you or I might require.
Be sure to ask me any other questions you may have.
In any case, have fun and enjoy your set. Don't wait until next Christmas to use it. :D
Hope this helps :)
Hitachi 32HDL52... | Answered on Apr 02, 2008
Hello Michael, I sent you the link of the user manual
I hope you can solve the problem
Greetings Franco Dosil
Hola Michael, te envio el link del manual de usuario
Espero puedas solucionar el problema
Saludos Franco Dosil
https://data2.manualslib.com/pdf2/47/4667/466619-hitachi/22ld5550u_users_manual.pdf?57aa459728c869ba6c471ef6617d380f&take=binary
Hitachi... | Answered 22 hours ago
Your Hitachi remote controls are not functionally interchangeable. Win some, lose some.
Hitachi... | Answered 2 days ago
Hello Grant, I am sending you the link to download the user manual of your Hitachi TV and check out the procedure of what you need
I hope that my suggestion serves you and you can resolve your concern
Hola Grant, te estoy enviando el link para que descargues el manual de usuario de tu TV Hitachi y consultes ah? el procedimiento de lo que necesitas
Espero que te sirva mi sugerencia y puedas resolver tu inquietud
https://www.libble.eu/hitachi-l46vf04u/online-manual-649167
Turn it off and then on again.
Please let it close for some time and then again turn it on.
Hitachi... | Answered on May 12, 2019
Hello Taimoor, it would be good if you indicate the Hitachi model that you have, to give you an accurate answer
You can try entering Menu, go down to System, enter with OK key, and go to Language Menu, press OK and the different languages will be displayed, choose the one you want, press OK and ready
I sent you the link To download the user manual of a Smart Hitachi 55 ", on page EN18, the way to do it appears
I hope you find my comment useful and you can solve your concern
Hola Taimoor, seria bueno que indiques el modelo de Hitachi que tienes, para darte una respuesta certera
Puedes probar entrando en Men?, bajar hasta Sistema, ingresar con tecla OK, e ir hasta Men? de Idiomas, pulsar OK y se desplegaran los distintos idiomas, eliges el que deseas, oprimes OK y listo
Te env?o el link Para que descargues el manual de usuario de un Smart Hitachi 55"
Espero te resulte ?til mi comentario y puedas resolver tu inquietud
http://www.hitachi-america.us/products/consumer/tv/docs/tvs/mx/alpha-smart-tv/M49N6_M55N6_Owners%20Guide.pdf
Hitachi... | Answered on May 06, 2019
Hitachi 32HDL52 32 in. LCD Television Logo
Popular Tags
13 questions posted
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
black box in middle screen
  • Televison & Video
