20 Most Recent
Hitachi UltraVision 42HDS52 42 in. HD-Ready Plasma Television Questions & Answers
I have a 2006 Hitachi Ultravision 42 inch plasma
plasma tv units use a lot of power ,well into the hundreds of watts 9 some big screens use up to 800 watts to work)
I suggest that you consider a new led unit which uses barely any power and you will get a remote with it
6/24/2017 9:06:33 AM •
Hitachi...
Answered
on Jun 24, 2017
I have yellow spots
Energy recovery section circuits have the fault. If you wish to know more details about these type of faults to Plasma displays,
check this link. There is more details with illustrations of screen shots.
If
you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock!
Instead, contact the nearest service center.
2/5/2013 3:30:23 PM •
Hitachi...
Answered
on Feb 05, 2013
Sound on but no picture?
Its from the model a Plasma----no single or easy answer for this--voltages in power supply in and out need to be tested and then at some point a scope used to check wave forms and then boards tried to see if a bad one or if the display panel itself is causing this(fatal).
11/11/2012 9:32:05 PM •
Hitachi...
Answered
on Nov 11, 2012
How to factory reset 42hds52
A hard reset rarely helps this sort of issue---look to see if speakers are switched on or off and does the unit work with only a DVD connected to one of the sets of AV jacks on the rear of the set.
9/2/2012 2:40:52 PM •
Hitachi...
Answered
on Sep 02, 2012
Hitachi 42" ultravision...power light on, hear
Tries pushes the power switch on the remote few times,each times push wait like a 1 mins or 2 mins for the tv Tuner signal board to take it effect.This process should get ur tv picture back,because the tv Tuner signal board it is old and having problems,evenually require replacement of a refurbish tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
10/24/2011 8:09:44 AM •
Hitachi...
Answered
on Oct 24, 2011
