20 Most Recent
Iomega REV ATAPI HDR B/U KIT CA 6 REV DISKS FOR 35GB EACH (742709334023) Media Questions & Answers
My Iomega Rev drive
FWIW, I had the same problem...here's what I did.
I would insert a disk and it would get ejected immediately...didn't even look like the light in the eject button would flash. Rebooting the drive and computer didn't work.
I inserted a disk.
Before it could be ejected, I pulled the plug on the Rev Drive.
I waited several seconds
Re-plugged in the rev drive.
It seemed to read my disk and I was able to use my Rev drive. (So far so good...knock on my wooden head.)
Luck
- J
Pen drive not getting detected? how to work it?
first go to my computer propery then hardware then device manager then go t ousb controller uninstall all usb drivers from there then just right click on any driver then click on scan for hardware changes then it automatic install usb drivers .
Connectyour pen drive to usb port check all port.
then if its not working check with other usb device is working with usb port?
Is it possible to use a 250 drive from my laptop?
Most of the shops will offer several solutions. The correct one for you will depend on the interface of the old drive. The drive was either IDE or SATA. SATA drives use a much smaller data cable than IDE. In either case, you can get a 2.5" drive enclosure for ~$30 or less. Alternatively, there are IDE/SATA/USB dongles. These allow the bare drive to be plugged in on one of the sides and the USB cable goes to the computer for ~$35-40. You have to be very careful to orient the dongle plug correctly to the drive data and power back plane. Incorrectly plugged in devices can be damaged. In the case of a SATA drive, there is the option of a hard drive dock (some can hold either 2.5" or 3.5" drives). for somewhat more. Some of these need external power; some of them can work off USB power.
I hope this helps.
(Newegg.com, Cyberguys.com and TigerDirect.com have various of these listed in their catalogs. I prefer the enclosures in my own environment due to pet hair and curious pet issues.)
3/14/2010 9:42:17 PM •
Iomega...
Answered
on Mar 14, 2010
Problem with oelmaier pac2 inverter
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjckMaPzKODAxUVj4kEHR5mBFMQFnoECBQQAQ&url=https%3A%2F%2Fforums.whirlpool.net.au%2Farchive%2F1447917&usg=AOvVaw1FGjdFQoufkwdXZJgXWdGz&opi=89978449
Inverter problems
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj_qqPyyKODAxWLHjQIHZRbAW8QwqsBegQIDhAG&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DZ6e4aMeAfGQ&usg=AOvVaw1gC1aMLjnqHmsV7v7EZaQm&opi=89978449
Rca 16mm projector 201 pg no sound exsiter lam of
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiX9MCToeeCAxWXv4kEHeF-DZcQFnoECCEQAQ&url=http%3A%2F%2Fwww.film-tech.com%2Fubb%2Ff1%2Ft000301.html&usg=AOvVaw3MnkgK0sKTHX7t5pvECIT5&opi=89978449
Lanzar sd82 input output plug layout
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwi8krnznueCAxWxrokEHT0iBfoQFnoECA4QAQ&url=https%3A%2F%2Fwww.manualslib.com%2Fmanual%2F577337%2FLanzar-Sd82.html&usg=AOvVaw1NvtQPbnDX49X9-I6oRe-J&opi=89978449
