20 Most Recent
JVC Cybercam GR-D71 Mini DV Digital Camcorder Questions & Answers
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
My GR_SMX730U VHS camcorder is eating the tape.It uses a PRO TC-30 casset.
that means the head is sticky or the takeup rollers are icky
take it apart . clean all the parts the tape touches with something thats strong but little water .
as for the head very carefull clean it when you get to the actual holes where heads are only use a proper qtip wetted . look it up or youll break them.
on the rubber rollers scrub them . then load the tape an watch it run.
its easy to fix this but you need a nice clean place an some small phillips , take pics of parts/screws if needed
Tape won't eject on my jvc gr-d60. help please.
Remove battery
Press and HOLD Eject as you place battery back on (so its the first command it recognizes with power) and try to eject. If it does not come out, camera will need service to remove tape or fix gears
