20 Most Recent JVC GR-D350 Mini DV Digital Camcorder Questions & Answers
TRi to check the take up wheel and idler gear or capstan motor is engaged with idler gear.
JVC GR-D350 Mini... | Answered on Feb 21, 2013
Hey,
I have the same problem and I found this fix in a service manual. It worked, but my tape motor adjustment is off. So be carefull.
The 3v dc is easy to make, connect 2 batteries 1.5v in serial, you get 3V dc.
Let me know how it goed.
JVC GR-D350 Mini... | Answered on Feb 09, 2012
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
JVC GR-D350 Mini... | Answered on Aug 20, 2011
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair cost low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If you are trying to capture footage from the tape you will need to connect with a firewire cable. USB will only connect to the storage card, usually assigned for still photos.
JVC GR-D350 Mini... | Answered on May 01, 2011
minidv jvc gr-d350 driver
JVC GR-D350 Mini... | Answered on Apr 12, 2011
If your selection to playback - mode to play back is selected- is correct then it is possible that the head is clogged with dirt and so the images were not recorded.
Insert an old recorded tape into the player and see if the camcorder plays. use the external video/audio output to be connect to your TV to confirm.
If so the head is clogged, have the head cleaned with a tape cleaner or very gently on the head tips on the drum taking care not to force and damage the delicate head ferrite tips.
JVC GR-D350 Mini... | Answered on Jan 05, 2011
Be sure to follow these instructions and let me know:
1- Set the camera on playback.
2- Push up or down the "Push" button and pressing on it and turn it up or down. You will see a speaker with a gradual degrees that indicate how hi or low the volume is.
3- Let me know.
JVC GR-D350 Mini... | Answered on Sep 15, 2010
Good day, here's the link where you can find the driver for you cam.
driver
JVC GR-D350 Mini... | Answered on Jul 26, 2010
Standard 1394 mini dv firewire. Ask any store that sells camcorders
JVC GR-D350 Mini... | Answered on Apr 28, 2010
Have you connected the 3.5mm stereo jack plug into the audio in on the PC the S Video cable only sends the component video signals {C Color (Chrominance) and Y Intensity (Luminance)} the audio is a separate connector
JVC GR-D350 Mini... | Answered on Jan 08, 2010
Hello
Thank you for using FixYa for your problem
you need the cable to record to your computer, mine uses a firewire cable
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
JVC GR-D350 Mini... | Answered on Dec 03, 2009
Either the dew sensor is defective or there is some condensation inside the unit. Try opening up the unit and pointing a hair dryer at it from about 12" away (enough to blow warm air inside the unit, not hot air). Let that run for about 10-15 minutes and try the unit again. If it continues to fail, than the dew sensor needs to be replaced. This repair shoold be done by a repair shop as cameras are not the easiest to work on.
Dan
JVC GR-D350 Mini... | Answered on Nov 13, 2009
In this model only you can connect when it is in memory mode.
JVC GR-D350 Mini... | Answered on Sep 12, 2009
JVC GR-D350 Mini DV Digital Camcorder Logo
49 questions posted
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GR JVC
  • GR JVC
Most Popular Question
driver
  • Video Cameras
