20 Most Recent
JVC GY-HD100 Mini DV Digital Camcorder Questions & Answers
I have a blue spot on my cameras image
From what I understand, the camera sustained a burn, similar to that of a retinal burn in the human eye. Once these receptor cells are damaged, they rarely become normal again. The good news, is the camera reception device can be replaced.
MY JVC GY-HD100 Wont capture properly in Final Cut Pro
Are you shooting 24p? Make sure you're using the correct capture presets. DV NTSC 48k 24Pa (presuming you're shooting 24p advanced)
if this doesn't help, close final cut and delete your com.apple.finalcutpro.plist file from library>preferences. This should solve additional cadence problems.
JVC GY-HD100 is unable to
You should select the Easy Setup preset that matches the cameras output before capturing.
You may need to start a new project for the Easy Setup to take effect.
Wat type of memory card do I need?
http://www.videomaker.com/article/12472/
Here is a link to a site that has written a review on your camcorder, and from what I've read you have a really nice camera. Congrats!! A few paragraph in it says it takes an SD card. You can get these upto 16GB as far as I know, but there may be a 32GB. you can get this at pretty much any store. Wal-Mart for sure.
View finder is not working.
lcd flexible cable is common problem in this model . try to move up down rotate if you see any picture change the flex cable
Pixel loss
you have to get to th camera admin menu
The fuse on my JVC
It is a very small fuse (about the size of a grain of rice) that is directly soldered to your circuit board. It is not a user replaceable part. You'll have to send it back to JVC to replace. In the future, what you need to do is power off when changing the battery.
Head cleaning required
i have the JVC MiniDV Digital Video Cleaning Cassette. I began having trouble when I was shooting DV24P and when I went to playback I noted audio dropouts. I'm using SONY Premium DVM60 tapes. I began having Head Cleaning Required message. I have ran the Cleaning Cassette and the message disappears, but even trying a brand new tape, switching to DV playback i get the error message. Luckily, the shoot i was on the master audio was being captured by a secondary device and we were able to simply use the video from my camera. Since then, I was able to play & capture both the video & audio previously recorded in HDV30P and I didnt receive an error message. Now though I cannot record any DV audio without dropouts. When I tested just moments ago, I was able to record HDV and both video & audio were clean, but during playback I still received the Head Cleaning message. Is the record head different from the playback head? Can you manually clean the heads by removing the plastic door cover with a lintfree cotton swab and rubbing alcohol (obviously disconnecting and removing all power & powering off prior to cleaning), the same way any previous machine heads were cleaned in our stations? I think I may have got a batch of bad tapes that may have gunked up one of the heads some where and its getting missed by the cleaning tape. Is is possible that the head has been scratched, and will require replacement. If yes, is there any way to look at the head and detect this?
